LS Vtec turbo set-up
Ok I'm on a mission to see whats what and how to get it down right the first time out.... I am starting to biuld up a B-18 LS vtec motor and want it to handle something like 15-20 pounds of boost... First of I'm woundering what all needs to be done to the block itself to prepare it for this amount of stress... Second will there be any major affect on the vtec head itself.... I have heard and don't quit full understand yet that I that I have to get a apex controler to have the vtec cut off so the turbo can kick in and take the rest of the rpm range..... I dont get it, why cant the VTEC stay in while the turbo is on??? I'm turbo and license illiterate on the subject.... or direct me to a: LS Vtec Turbo 101 link.... thanks for any info..... "gotta dip out to werk"
shut up and race....
Who have you been talking to?
VTEC does not have to be turned off when you have a turbo..
I am assuming that with the boost numbers you stated "15-20lbs" you already know there is ALOT of money involved to have a reliable setup...
PM me if you want to know more, there are also a couple of guys running good LS/VTEC Turbo setups on this board besides me.
Guest
Posts: n/a
Ya know, someone else recently asked me about "VTEC and turbo not working". These people are morons. VTEC most certainly works great with turbo.
To answer your question, if you want to run 20psi, your going to want a sleeved block, and forged internals. Quickcivic here can help you out if you want someone's expierences.
Tight I'm going to need some help w/ this I know..... I'm planning to pick up a second job so I can have it done the right way the first time.... But I'll get up w/ you two friday or so I have to work all night and 10 am to 3am tomma.... I'll pm ya after some well deserved sleep to get some low downs.... thanks
a whole lot of money for that boost range. Say 8-12 can be don't reasonably
NEED PARTS WTB: Turbo Timer, TIAL 38MM+ WGATE, Race Manifold, etc
NEED a FPR installed!!
White 97' kouki RIP
Green 96 TURBO
White 97' kouki RIP
Green 96 TURBO
Well my #'s were preety much around 12 to spend after some time..... the main thing i was looking for is what is involved and a good how too... This i know by far isnt going to be an over night project i know.... Namely for the rason i'm the one paying for it... lol.... not lucky enuff to have rich parent type's actually none of those either.... lol.... the other question i was wondering is whats the best bore size for this.... that can still keep the car as a daily driver w/ poor gas milage.... lol..... one other thing i'm also moving from the tegra to a crwrecks...... plans are werking that right now....
thanks for any help.... peas owt...
Hey man I havnt done a LS VTEC turbo but i am in the process of building my budies GSR Turbo and hes shooting for like 20 psi and you will spend about 10G's EASY !!! Actually its built just waiting on the intake manny and tranny so we can drop it in. If you need any help or info hit me up its still fresh in my head !! we have info posted with pictures in the EMANAGE IN ENGLISH post
Sleeves, pistons, rods, block girdle, bearings. Machine work on the vtec head(drill, tap, weld, plug, dowel pins, etc), oil lines...those are your basic Ls-v setup that you will encounter. Not to mention all the turbo stuff. I know what needs to be done, but I would suggest you doing a search as this can get very spendy in a hurry when building it correctly. I can help you out, but I would look into the Ls-Vtec conversion searches first.
Jason
Jason
thanks for the info, See I have managed to pull a LS B-18 block that has had the v-tec head on it before.... So you can say at least that part has bee done.... Currently I am looking for a Morroso Oil pain "5 qt" and an oil cooler.... Starting w/ the block first.... My wondering is this I dont know the person that owned or biult the block but I was there when the head came off... How can I tell if it has been resleeved or w/ a Vtec head would it have been resleeved to handle what was on it??? I do know that the there is rods and ARP bolts on it all ready, but not sure about anything else... hit me back and let me know anything about what to look for....
TR Wondering WTH I moved from FL Member.
Back Then: A stupid Question was one that wasn't asked.
Today: A stupid question is one that wasn't Googled / Ixquicked first.
