Paint, Body, and Detailing Discussions on how to keep your ride clean, shiny, and straight
polishing compound ?
Old Feb 17, 2011 | 07:34 AM
importguy1208's Avatar
Wide Open and Sideways!
Originally Posted by 96spydergst
Ok? so becuase i used a tractor paint glossy enamel i cannot
buff it or anything? I know I can clearcoat it. dont bash it that hard.
how many of you are just jumping to you cant do anything
becuase its a diffrent paint? Help me out
guys... I know i could repaint it easly. all the body work is done
keep it on topic...polishing compounds
I say you have three basic options for making it shiny.
1) You wet-sand it with 600, 1000, 1200. Then buff it with a wool pad and some heavy rubbing compound like 3M Super Duty Rubbing Compound. Then come back with a product like Finesse-It II or Perfect-It Foam Polishing Pad Glaze with a black foam pad.
2) You wet-sand it with 600, then clear the car.
3) You wet-sand it with 600, then basecoat/clearcoat the car.
Paint & Body Work, Fiberglass/Carbon Fiber/Kevlar, Mechanical/Fabrication/Welding Phone: (352) 286-4557 Text or Voice
Old Feb 18, 2011 | 12:11 PM
96spydergst's Avatar
Default ...
Thank you. someone came up with a real solution. #1 is way to harsh
#2 sounds like what i want. any quotes on clear coat?
per coat? Just made 1,000 in 3 days serving tables. and its payday.
I believe in a lively disrespect for most forms of authority.
96 eclipse gst drop top sold
98 civic EX sold
94 civic EX sold
94 cx H22A1 whippin
Old Feb 18, 2011 | 05:59 PM
A gallon of NASON runs around $120-150 retail, depending on where you get it and if you get a discount or not.
If you just wanted an outside scuff and shoot of clearcoat I would charge around $300 plus materials. That would be a light coat, followed by two heavier coats. I'm sure someone will do it cheaper. I'm just stating my price.
Old Mar 7, 2011 | 09:11 PM
ibidu1's Avatar
Are you guys sure clear coat will stick to enamel?
You can always lightly wetsand a small area, buff it out and then use a glaze compound. 3m Glaze is what cheap detailers or car dealers use to make a paint shiney for about a month or two. It hides a lot of small imperfections
Mafiakiller
Jan 18, 2011 07:40 PM
330SMG
Advance Performance Tires
Jan 11, 2008 05:46 AM
JayLude
Jan 31, 2007 09:04 AM
integralsgreen
May 17, 2005 05:59 PM
