Paint, Body, and Detailing Discussions on how to keep your ride clean, shiny, and straight
Polishing Wheels
Old Jun 12, 2007 | 09:33 AM
EK4Door's Avatar
Originally Posted by Alswizzo
looking good with the rims...repped!
thanks...rep returned
Old Jun 12, 2007 | 02:27 PM
Lay Maha's Avatar
Jaded Mitsu
what are the shrot cuts? the wheels look aftermarket now. Good job.
Old Jun 12, 2007 | 03:20 PM
xnissan240x's Avatar
Fishes more than you
i would like to share
before
taped up getting primed
awww shit
finished after 4 hours a wheel prepping, painting and polishing
Old Jun 12, 2007 | 04:20 PM
EK4Door's Avatar
There was quite a few...Let the aircraft stripper set for about 15-20 minutes to really get the clear good and loose. Use a pressure washer to clean the clear and aircraft stripper off, instead of taping them off I used Mothers to coat the lip before painting them, it kept the ovrspray off and made it a lot quicker. To finish them off I used a rag with laquer thinner to remove any unwanted paint. PATIENCE is the key.
Old Jun 13, 2007 | 12:26 PM
CARNAG3's Avatar
ROTM March 2013
Best LS wheels I've seen yet. Good work! Im still curious about the mothers on the lip. What exactly was it you put on and how did you get the paint edge so straight where the lip meets the paint?
Old Jun 13, 2007 | 02:47 PM
Bluballz's Avatar
"Diversify Yo bonds!" GZA
How did you apply the paint? Did you use a clearcoat and primer?
Old Jun 13, 2007 | 03:36 PM
  #17 (permalink)
EK4Door's Avatar
I used the mothers before masking off the lip of the wheels, just a trial to see if it helped in keeping overspray off and it worked great, when the overspray got on the area with mothers it wiped off, should have taken pics. The paint edge was pretty easy to get straight, I painted a little too far and then took a rag with a little laquer thinner to get them straight, there is really thin lines on the Mesh's so I could line the rag up in that line to wipe them straight.
Old Jun 13, 2007 | 03:37 PM
  #18 (permalink)
EK4Door's Avatar
Sanded them before painting them, I did not prime them first, used three coats of wheel paint and then three coats of wheel clear.
Old Jun 13, 2007 | 03:38 PM
  #19 (permalink)
crx_monster's Avatar
bump.... nice rims they are sweet
speed makes me crazy
Old Jun 13, 2007 | 04:09 PM
  #20 (permalink)
EK4Door's Avatar
thanks....just need to find some center caps
