Paint, Body, and Detailing Discussions on how to keep your ride clean, shiny, and straight
Water spots..
Old Mar 22, 2007 | 06:14 PM
TSX24L's Avatar
Default Water spots..
How can i get hard water spots off my jag? I tried waxing and it still shows up. Ive tried washing the car and wiping off the water right away and it still is there. I have never used a clay bar which I was looking into. Any advise please?
Old Mar 22, 2007 | 08:32 PM
TrboANTsi's Avatar
FL,..gods waiting room!!
calybar will definetly do the trick.and its quite easy to do just takes lots of time. get the mothers claybar kit. its good for about 2-3. all youdo is spray the instant detailer and rub the bar. but you cannot drop it once dirt gets in it ...its ruined and could risk scratching your car..now what i started doing was using filtered water from inside the house, since i havea water softner system. but the claybar kit can be found for about 14 bucks. at advanced or walmart wherever..and it will take off any contaminents make it feel like it rolled off the showroom floor no joke.
Old Mar 24, 2007 | 07:08 PM
240gun91's Avatar
i agree use the clay bar. i used it on my car , it took hours but it turned out amazing, i went out later that day and had several comments from people who thought my car was repainted. Clay bar is the way to go.
Old Mar 25, 2007 | 05:46 PM
jlmaxima4sale's Avatar
if clay bar doesnt work you can do a simple wetsand and buff using the trizact 3000 grit disc by hand and use water then buff out with 3m perfect it 2 compond and go over that with 3m perfect it machine glaze i use to work for gulfshore collision which was aston martin jaguar of tampas bodyshop and thats how we did it there
Old Mar 26, 2007 | 04:26 PM
Hellfire_Studios's Avatar
yeah the clay bar should fix your problem
Josh @ Hellfire Studios
Custom Paint, Collision, Bikes
<Severed Ties> FL
"Diamonds are forever!"
Old Apr 15, 2007 | 11:28 AM
mbanks21's Avatar
Try not washing it with hard chlorinated water
Old Apr 22, 2007 | 05:22 PM
dragula's Avatar
Motherfuckin Trend Killer
Vinegar in the wash water
Thats right fools, 2 Prostockers this year
Old Apr 22, 2007 | 11:55 PM
X2daC's Avatar
Been here since 03
After all is said and done. Switch a de-ionized wash system. If you can't afford that, pick up a Mr Clean Auto Dry washer. Same thing, just a bit more easier on the pocket.
Originally Posted by presidential
I've taken shits more substantial and more intelligent than you.
Old Apr 24, 2007 | 07:00 PM
.Seth.'s Avatar
TR Balla Donor Supreme
no no no, was the car like u do regular(1 1/2 at a time, then go and dry it off w/ a damp rag, make sure it doesnt leave lint) when i worked at the car was thats wat we did and we never got spots
Old Apr 24, 2007 | 07:19 PM
GOTTI's Avatar
OEM Parts Specialist
This would be the best way to do it. I use the same procedure when i wet sand and buff. The 3000 grit disk can be used on a soft DA pad also with water for a quicker turnout.
