Setting S14 KA TPS Voltage
Old May 5, 2013 | 04:01 PM
OneCleanS14's Avatar
Default Setting S14 KA TPS Voltage
So i got my new tps from nissan. Installed it and everything. Went to set the tps voltage using the write up on nico. Followed it but im getting wayyyyy different voltage readings from what the write up says. I noticed that the write up is on a S13 KA. Im pretty sure the tps is different from an S14. I have the Two connector tps. A 3-wire connector and a 2-wire connector. If anyone can help me out that would be awesome.
KA-T.
Enthalpy Tuned.
Old May 6, 2013 | 04:33 AM
Epstein's Avatar
Retired
Too lazy to go look up the wire colors. Just probe all 5 wires with a voltmeter until you find the one that is in the 0.3-1.0V range. Adjust the TPS to hit the voltage you want. You can ground the meter to the intake manifold. It's probably one of the 3-wire connections.
Old Jun 19, 2013 | 01:28 PM
Empire's Avatar
buildin' it
boom!
Frankie Figs
Audio HQ
7
Jun 13, 2008 07:03 PM
Stephan
Jan 5, 2004 05:00 PM
Sangui
Feb 8, 2002 02:45 PM
