Replacing Rings: KA- hgh compression question/suggestions.
Tom, If you have been high comp for some time with your DSM stuff, what suggestion would you have for rings? Did you build your engine or take it to a shop?
Honestly, I'm bummed though Tom
. I thought for sure you would think this venture would be worth checking into for the sake of doing something different, at the very least. But you did highlight why I want to do the super charger set up..."everyone" uses a turbo to boost
http://youtu.be/jN3c_BkQ89M Between Empire and myself, we have researched the shit out of the supercharging topic. We are well aware of the limitations of supercharging. If youre interested, take a look into my build thread. There are plenty of details in the thread.
All that is well and good, but if I dont get my rings replaced then it wont matter anyway...lol. My compression right now is crap...the car is eating too much oil and it turns black in a matter of 300 miles or less.
As Ive stated in this thread earlier I only have around $100 invested in the engine right now. Its eaten up a fair amount of time with its odd complications (from head gasket to flat top piston discovery), but is still intriguing as a project. In the worse case it gets build then pops...then we build the other engine block we have here.
If it has tires or boobs it's going to cost you money...
Those look exactly like the oe replacement beck arnley sohc pistons I put in my dohc high comp build a couple years ago
As far as the rings go choices are endless mostly opinion based but just make suure you gap them extra wide right at the max spec of the rings this will allow for them to expand more due to the extra heat they will be experiencing with the higher compression.
If you don't gap them wide enough they will end up expanding to the point that they actually push togeather and cause so much extra friction against the cylinder walks that the ring lands will fail
jdmbitch21
For Sale/WTB Honda & Acura
Sep 3, 2010 09:25 AM
jdmbitch21
7
Sep 2, 2010 11:47 AM
