S13 KA - Running Rich
Old Feb 18, 2012 | 07:08 AM
rhart's Avatar
Because race car…
Default S13 KA - Running Rich
Fellas,
My 240 is running kinda rich. The performance of the car is not terrible. It does NOT do the usual bogging thing that is common with a too much fuel situation. But my fuel mileage is a little on the low side. I average between 18-21mpg in town. The biggest issue is that the exhaust just smells funky and is noticable if your riding behind the car as well. It does puff smoke occassionally when i start it up or leave a light, but oddly, that comes and goes (which could just be valve seals). I picked up a PVC valve to replace after seeing what replacing one in another car did for it. But that job is a PITA.
Do any of you have any suggestions for what could be causing my issues?
The engine, a s13 KA24DE, has a short ram, a good portion of the emissions deleted (which could be part of the fault) and a 4-2-1 header.
Always appreciate the input...
Thanks,
-Royce
Old Feb 18, 2012 | 08:36 AM
KRUKED's Avatar
.....taste the rainbow
O2 sensor, plugs...
You know, somebody actually complimented me on my driving today. They left a little note on the windshield, it said 'Parking Fine.'
Old Feb 18, 2012 | 08:57 AM
rhart's Avatar
Because race car…
It has been a while since I've done a basic tune up on the ol' gurl. She is due I quess...
Old Feb 18, 2012 | 08:32 PM
Empire's Avatar
buildin' it
*cough*vacuum leaks*cough*cough**
Old Feb 18, 2012 | 08:45 PM
Empire's Avatar
buildin' it
if it was me, find and clean up and possible vacuum leaks, anything from old emissions things, to intake couplers.
Tune up, all the way around, from the fuel pump sock, all the way to the plugs and wires, to the air filter. Make sure everything is nice and clean and fresh.
get a fresh pcv on there, who knows how old the one on the engine is. that could make a decent difference all in itself.
Clean the MAF senor. I don't remember what kind of filter you had, but if it is one of the ones that is supposed to be oiled like a K&N, then either the oil itself can get through the filter and coat the MAF, or, if you don't oil it, then little bits of road grime can get through the filter and coat the maf
Make sure you are getting the correct fuel pressure, and not stuck at max psi all of the time.
I'd get a fresh o2 sensor on there, just to be sure, unless a wideband is in the near future.
Because you did remove those emissions, you should be running a bit rich. Remember, the stock tune is set up to have that little bit of extra air coming from the EGR valve and all of that. So once everything is all nice and fresh and in good shape, you should still be pretty rich. I found that I was able to run much more advanced timing because of that, and that helped even it out the mpg.
Ideally, you would do all of that nice "powder its nose" type of stuff then get some kind of tuning to bring the mix back down to where it should be. A wideband o2 sensor and a safc would go a long way. While normally, I wouldn't suggest a safc, since you don't have boost or anything like that to really worry about, you can get away with just a simple safc tune. All you're trying to do is get rid of the excess fuel anyway. But, don't just get an safc and run with it, you really need the wideband to tell you where you are at. It is really easy to over do it with an safc.
Old Feb 19, 2012 | 03:13 PM
rhart's Avatar
Because race car…
Yeah...i hear ya Empire...i'll be searching for those out too. Might even pull the distributor and correct what appears to be a "one tooth off" situation.
I could just tollerate the issue til i boost the damn thing... :\ Having patience as i wait for that plate is tough. All solid suggesstions guys. Thanks!
-Royce
25 to LIFE
May 22, 2010 09:26 AM
Brandon
Nissan/Infiniti Tech
6
Feb 12, 2005 09:52 PM
spoonfed
Mar 7, 2003 06:22 AM
88EFSiR1J1
Mar 4, 2002 11:31 AM
