sr20det help needed
Old Oct 7, 2011 | 12:48 PM
JDM Pollo.'s Avatar
will eat for more food
Originally Posted by 84_GT_turbostang
I have tested several times for boost leaks and havent found any except a tiny one from the BOV
leaks on the BOV can make the car run like total shit, fix that leak and see what happens.
I sell LED's for gauge clusters, side-markers, dome lights, map lights, license plate lights, corner lights, etc. Whatever you need, i have it all. Contact me for more info or pricing: (813)-516-3118.
Old Oct 7, 2011 | 02:14 PM
Jubee's Avatar
Baby Rhino
if your MAF is ok i would also check your CAS thats what mine was doing and the CAS was going bad
Old Oct 7, 2011 | 10:39 PM
84_GT_turbostang's Avatar
I can't get the bov to seal and how would I test the cas?
Old Oct 9, 2011 | 09:22 AM
juiced2ndgenteg's Avatar
^swap a known good one in?
Old Oct 10, 2011 | 05:09 AM
dont have access to a known good one. also found out today when the car is cold it does the same thing when i go WOT but it will make around 9psi before it starts fucking up
Old Oct 10, 2011 | 11:28 AM
does it stop every time at the same rpm? if it does, CAS is bad/going bad and is in limp mode. Does it only happen under boost conditions? then its missfiring so, coil packs, spark plugs, fuel. fairly simple.
Old Oct 13, 2011 | 04:53 AM
  #17 (permalink)
markstheman365's Avatar
cant slide
stock turbo?
i deleted my bov, it ran like jesus...my leaking bov netted me about 6-10 mpg
after i deleted it, i got about 27 mpg. not great for your turbo, but ehh
I also had the same issue when i was using a carter replacement fuel pump....drove fine until about 3k in boost, then it would lean out badddddd
ps: i asked if its stock turbo, just because i wouldnt run comp surge on a nice expensive turbo
contact admin@tamparacing.com to advertise on here.. - mod
Old Oct 19, 2011 | 07:56 AM
  #18 (permalink)
Originally Posted by markstheman365
stock turbo?
i think ill try taking off the bov
it only does it in boost so ill check the plugs
Old Oct 20, 2011 | 07:36 AM
  #19 (permalink)
so i was driving yesterday and the car shut off now i have no fuel so i think its the relay
Old Nov 3, 2011 | 03:42 AM
  #20 (permalink)
BucWildBob's Avatar
check vacuume (sp?) lines to fuel regulator. if you have access to a halfway decent obd scanner, look at live data. It will give you a value for your maf. see what it does. also while looking at live data make sure all the other numbers look correct, like coolant temp and all that good stuff.
Chankisonfire
For Sale/WTB Nissan
6
Jun 27, 2010 04:22 PM
johnnunez29
Nissan/Infiniti Tech
11
Apr 21, 2009 02:46 PM
WhiteNgold
8
May 30, 2008 07:00 PM
Frankie Figs
14
Sep 16, 2005 03:24 AM
