Excessice SR20DET blow by question
Old Sep 4, 2011 | 11:04 AM
omgosh's Avatar
140 is by no means good compression. You can get by for awhile if you dont beat on it too much and route that to a catch can.
Old Sep 4, 2011 | 11:38 AM
-Mike's Avatar
Formerly IThaJokaI
Its not?
I told you either the rings were gone or the valve seals are gone, doesn't have to be a compression ring to leak.
Old Sep 4, 2011 | 03:45 PM
Jr_SS's Avatar
S one 4
140psi is only 15psi less than stock spec. If you think that's bad comp you need to have your head checked...
Old Sep 4, 2011 | 04:14 PM
Empire's Avatar
buildin' it
Originally Posted by JDM Pollo.
wouldnt be the ring lands cause compression is bueno. and it isnt gushing, but it will leak out. like after a test run with boost a small puddle of oil is chilling on cyl 1 and 2 of the manifold
might not be the lands, but it could very well be the oil seals if that much oil is coming out.
Originally Posted by Jr_SS
Oil control rings are fuxored... You need new rings my friend
that's what I'm betting my money on.
Originally Posted by mewantkouki
Leakdown test > Compression test
can't really think of a time where this isn't true...
well, thats all he had available at the time. couldve just simply said "try a leakdown test".
but then you would have missed the bit about that mad tyte JDM breather.
I wouldn't go as far as to say it is bad compression, but for an SR it is alright. now 140 on a KA might be cause for concern.
Originally Posted by -Mike
Its not?
I would lean more to the rings side. If it was valve seals, there would be smoke
I don't know, last time I had my head checked, "they" said it was good, but to me, a 10% drop in compression isn't a good thing. It isn't a "OMG that's terrible" thing, but I sure wouldn't write home and tell momma about how great my compression is when it is 10% lower than stock.
Old Sep 4, 2011 | 05:34 PM
JDM Pollo.'s Avatar
will eat for more food
but when you put into consideration that the motor has over 50k miles lets say shit is going to be worn down a bit. just saying
I sell LED's for gauge clusters, side-markers, dome lights, map lights, license plate lights, corner lights, etc. Whatever you need, i have it all. Contact me for more info or pricing: (813)-516-3118.
Old Sep 4, 2011 | 06:22 PM
Blackzenki82's Avatar
(OO\____/OO)
50K with a proper break in should last, event event after event.
my bad SR? the comp numbers were 175, 170, 135, 180 (thottle closed). when i tore the motor down, the oil rings and lands were cracked and broken... just saying...
no proper break in, and improper maintainance will burn a motor up in 50K miles easy... hit 4-5 events (or a shit ton of daily driving abuse) on one oil change because "it hasn't hit 3000 miles yet" or whatever will kill a motor, starting with rings/lands...
Originally Posted by sean1
Shit'll buff out.
Old Sep 4, 2011 | 08:01 PM
  #17 (permalink)
JDM Pollo.'s Avatar
but your comp is way off, his is 140,140,145,150. no big dips or anything. did the test warm, and throttle plate open. i guess we will just keep searching and searcing till theres no choice but to tear the engine down, and see whats up down there. i will contact the seller and notify him about whats happening though. not to complain but to tell him whats going on since he wanted to know.
Old Sep 4, 2011 | 09:49 PM
  #18 (permalink)
-Mike's Avatar
Formerly IThaJokaI
180 compression for a SR is higher than OEM spec...
Old Sep 4, 2011 | 11:20 PM
  #19 (permalink)
(OO\____/OO)
oil was being pushed through the spark plug O ring, a bunch drained in when i pulled the plug.
Shit'll buff out.
Old Sep 5, 2011 | 07:09 AM
  #20 (permalink)
JDM Pollo.'s Avatar
So that would be your valve cover gasket. Nothing to do with what we are talking about.
