Wiring gurus, need your help!!!
Old Jul 2, 2011 | 03:27 PM
Enemy S15's Avatar
So there I was bak in NAM
Default Wiring gurus, need your help!!!
I am using a S14 (95) Jdm Chassis and Dash harness on my 95 USDM RHD conversion. I am retaining the USDM upper and lower engine harness. I have everything almost everything wired up and I have a couple of problems that I hope you guys can help me with.
1: Jdm Wiper motor is constantly running, regardless of what wiper speed I set it on (jdm wiper switches). Thought about taking out the internals from my Usdm wiper motor and installing them into the Jdm wiper motor.
2: When I use the turn signals (Jdm switches), the side bumper markers work, but the corner turn signals don't work. (everything should be plug and play, to my knowledge, but I seem to have this problem)
3: I am using the USDM rear chassis harness. I know the dash JDM dash harness pins do not line up with the USDM rear chassis harness. I am wanting to find out what JDM pins corralate with the USDM rear chassis pins, so I can repin them in the correct place. (When I plug in rear chassis harness into the dash harness, obviously nothing lights up. When I switch the turn signal to the left, I hear the antanae motor turn on)
Thanks
Billy C.
A Father Never Forgets.. In loving memory of Chasen Alexander Centeno. March 5th, 2004.
Old Jul 13, 2011 | 08:07 PM
Enemy S15's Avatar
Better explination with pics..... This is the rear tail section USDM wiring going to JDM CHASSIS AND DASH HARNESS
Shows the rear USDM harness connector along with 2 gray connectors (right of the connector). What do those 2 gray wires run to Anyone know what color cables coincides with what on that connector?one has black tape around and the other has yellow tape
2nd pic is the JDM SMJ from the main harness. Anyone know what color cables cooincide with what on that harness connector?
3rd is the USDM rear harness and the cables. If you notice the USDM harness has more cables than the JDM harness. I am trying to figure out what goes to what so i can match em up and call it a day.
Anyone that can either
provide me with the info to repin the USDM harness to match the JDM harness
OR
Has the knowledge to do this for me
I Would greatly appreciate it!
Thanks
Billy C.
Old Jul 14, 2011 | 04:21 AM
mewantkouki's Avatar
no
There are fsm with wiring pinouts for USDM 240sx and JDM silvia in the help sticky. There are maybe 3 or 4 people in Nissan Tech that would be able to answer your question off the top of their heads.
Old Jul 14, 2011 | 05:51 PM
Enemy S15's Avatar
Got names of said people. I'd like to purchase their knowledge to get this done ......
Billy C.
2qk4u
Jul 5, 2010 05:04 PM
hmmracing
Aug 12, 2009 08:45 AM
Jonas
Nissan/Infiniti Tech
10
Jan 7, 2007 02:43 PM
importeclipsegst
Nov 7, 2006 02:38 AM
Flastangs
Oct 20, 2005 12:23 PM
