sr20det valve shimming.
Old Jun 13, 2011 | 05:54 PM
dwrec37's Avatar
Default sr20det valve shimming.
i have greddy valve springs and installing step 1 cams, i've been searching for the stock valve shim clearance, but can't find it.. anyone know a link? or know what it is off the top of their head..??
Old Jun 13, 2011 | 06:00 PM
Jr_SS's Avatar
S one 4
.025mm or .001in is factory spec...
Old Jun 13, 2011 | 06:19 PM
Epstein's Avatar
Retired
This is the stock mismatch/tilt between valve pairs. The rocker to lobe clearance is zero.
Old Jun 13, 2011 | 08:43 PM
dwrec37's Avatar
And tht is for both intake and exhaust? On a cold head? Or should it be measure when head has reached running temp?
Edit " thanks for the help"
Old Jun 13, 2011 | 09:21 PM
supreams14's Avatar
Keep the shims in the same location and there is no need to reshim anything unless you replace or lap the valves. Re shimming the valves is a BIG PITA!!!
Old Jun 13, 2011 | 09:52 PM
dwrec37's Avatar
Valve's we're lapped, and greddy springs installed.
Old Jun 13, 2011 | 10:14 PM
supreams14's Avatar
Well you better have a good sr20 valve shim tool or access to one! It is very important to have the exact shim size or the motor wont run properly!
Old Jun 14, 2011 | 04:04 AM
Epstein's Avatar
Retired
Cold head, intake and exhaust. Basically, the rocker has to be perfectly flat (less than .001" difference in height between intake pair / exhaust pair). The SR head is hydraulic lash, so what we would call the clearance is automatically adjusted. You'll need a tip height tool for the SR head to measure this. RP Sport and Custom Steel both made this tool, but they've nearly been wiped from the internet. Mazworx made their own but do not produce them. I made my own janky one from Harbor Freight parts.
Old Jun 14, 2011 | 06:24 AM
dwrec37's Avatar
Well thts a bummer, epstein u wanna make a little cash, ill bring my head and cams to you..
Old Jun 14, 2011 | 06:26 AM
Epstein's Avatar
Retired
Find Z28ricer on here. I bet he'd be happy to work on it for a little cash!
JimmyHat
For Sale/WTB Nissan
4
Jun 28, 2006 07:40 AM
JimmyHat
Drifting
10
Jun 16, 2006 03:20 AM
Evangelion
For Sale/WTB Nissan
4
Mar 21, 2006 03:31 PM
sam21
Mar 19, 2006 03:50 PM
Plopokiller
Nissan/Infiniti Tech
8
Mar 5, 2003 05:37 AM
