s13 rear suspension question
Old Jun 1, 2011 | 04:40 PM
Your welcome's Avatar
Default s13 rear suspension question
So I bought an s13 hatch a while back, I notice that the outside of the tire is wearing down a lot faster than the inside. So I took the tire off and noticed these. What does this mean? bad bushing? bent arms? the pictures dont show much, just that they are crooked. any ideas?
[ATTACH=CONFIG]156866[/ATTACH][ATTACH=CONFIG]156867[/ATTACH][ATTACH=CONFIG]156868[/ATTACH]
I took it to a tire shop a few days ago to see if it was just my alignment, they wanted to put in a camber bolt, if it matters.
Old Jun 1, 2011 | 04:42 PM
weird... pictures dont show unless you click the picture and move the mouse around
Old Jun 1, 2011 | 04:50 PM
David48's Avatar
I <3 usdm
As far as I know that doesn't really mean anything. Your best bet is to just go get an alignment.
Potato
shit got all davided up.
Old Jun 1, 2011 | 07:18 PM
Empire's Avatar
buildin' it
the bushings could be replaced, but that's within the "acceptable" range of flex.
And David's right, just take it to an alignment shop and get it aligned.
IF something is busted, then they will let you know.
Old Jun 2, 2011 | 09:01 AM
rhart's Avatar
Because race car…
Is it lowered?? Springs Cut? Check the lower control arms ball joint. Installing new bushing BEFORE you get it aligned would be best if you choose to go that route.
Any decent alignment shop would point you in the right direction on how to correct the wear. I wonder why they wanted to install the chamber bolt??
If it has tires or boobs it's going to cost you money...
Old Jun 2, 2011 | 12:32 PM
jdm_S14's Avatar
(O=O/-180sx-\O=O)
Firestone does free alignment check.
But I'm certain those 20+year old bushings aren't helping.
Old Jun 2, 2011 | 01:11 PM
rhart's Avatar
Because race car…
^ speaks the truth.
Old Jun 2, 2011 | 01:12 PM
rhart's Avatar
Because race car…
Is the s-chassis from the bay area? There is lots more rust on that bad boy than i'm used to seeing.
Old Jun 2, 2011 | 02:27 PM
Blackzenki82's Avatar
(OO\____/OO)
there is a shit ton more rust than we florida guys are used to seeing... most florida arms are still black, although covered with 30 years of road dust...
Originally Posted by sean1
Shit'll buff out.
Old Jun 2, 2011 | 04:33 PM
DSMSpoolin's Avatar
Judge Fudge
Those bushings are shot for sure. but then again no stock bushing was made to last twenty years. You can still get it aligned but it would probably be in your best interest to either replace all those bushings or get after market replacements. Its ALOT easier to get after market replacements. if the outside of your tire is wearing more then the inside i would first grab a set of after market rear upper control arms that you can adjust yourself. I mean if your planning on getting coilovers you are going to need to replace all of those parts with after market parts anyway because you cannot adjust the stock arms once you lower your car. the factory bolts arnt made to correct that.
Also dont waste your money cutting or heating the springs. it will end up costing you more in the future. grab some coilovers and replace the multilink parts right and itl look great and ride nice.
Love
Your friendly neighborhood Neil.
Many cars: Sold
1990 black top SR 240sx Coupe: Current
They use shitty skylines like this as taxi's in japan
JDMbyBlood
Nissan/Infiniti Tech
Nov 23, 2009 08:53 PM
Ares
Chassis & Suspension Tech
Oct 17, 2008 11:24 AM
Zate
Nov 25, 2003 02:58 PM
ponchoV8
4
Mar 6, 2003 07:35 PM
