rb25det running hot!!
Old Apr 5, 2011 | 01:30 PM
Empire's Avatar
buildin' it
Oh damn!
how does that even happen
AWD4g63's Avatar
damn that pump is fuckeddddd
i doubt mine is that bad seeing as how it was replaced about 10k miles ago. but stranger things have happened. i guess ill find out in a couple weeks when i replace mine.
Skyvia - The Best of Both Worlds
Old Apr 5, 2011 | 01:37 PM
Blackzenki82's Avatar
(OO\____/OO)
i've seen RB water pumps with the vanes completely rusted off, nothing but the center hub spinning...
replacing one is a bitch...
use distilled water...
Originally Posted by sean1
Shit'll buff out.
Old Apr 5, 2011 | 01:42 PM
AWD4g63's Avatar
whats your opinions on a high flow inline electric pump? ive seen them on sr20s before but never on an rb. think it would be worth trying?
Old Apr 5, 2011 | 01:45 PM
(OO\____/OO)
just get a N1 pump and call it a day.
Shit'll buff out.
Old Apr 5, 2011 | 01:50 PM
AWD4g63's Avatar
ok will do.
Old Apr 5, 2011 | 03:51 PM
  #17 (permalink)
Empire's Avatar
buildin' it
the in-lines aren't bad if you have the extra amps to play with.
I don't know that I would rely on one though.
Old Apr 12, 2011 | 01:34 PM
  #18 (permalink)
sullivanracing06's Avatar
N1 pump
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old Apr 12, 2011 | 04:48 PM
  #19 (permalink)
BABILLARACING's Avatar
man you are dealing with the same situatio i am dealing but my engine is a 2j.I have it down to 184-195 f cruising and 195-204 at idle on traffic. before it was in the 200-225F range. I wired a fan wrong and change the radiator cap from 13psi to 16psi. so you know .I have a friend with an isis rad and the cap took a shit in a month
My shit still slow
618 whp 492 ft/lbs at 22 psi (Low Boost)on pump gas ,
stock block ,more power coming soon ,stay tuned
Tuned by Alpha @ Induction Performance
Old Apr 20, 2011 | 11:09 AM
  #20 (permalink)
AWD4g63's Avatar
Update!! Pulled the waterpump....and its fine. So I wasted alot of money on a n1 pump. So im gonna go get my radiator hot tanked and chemically cleaned at a radiator shop. And if that doesn't fix it then im stumped. Im still gonna try the n1 pump and hope that helps a little bit.
