Serious Injector Problem(fully built ka)
Im going to double check my spark. I actually haven't checked that but I should. Sorry for getting crazy about the build but it truely is. Sorry Z28
Carisma Built Ka(BC Valve, Springs, Retainers, JE Pistons, Eagle Rods,Cometic HG, Supertech Intake Valves, Supertech .5+ Exhaust Valves
Garrett T3 .63 A/R
Bc Stage 2 Cams
Z32 Maf
Injector Dynamics 725cc
10lb Tial Wastegate
Open Downpipe(blah)
Greddy Type S Bov
Enthalpy Rom Tuned
Garrett T3 .63 A/R
Bc Stage 2 Cams
Z32 Maf
10lb Tial Wastegate
Open Downpipe(blah)
Greddy Type S Bov
Enthalpy Rom Tuned
Martin is going to be at my house on saturday to take a look at the problem and see if he can correct it. Hopefully he does cause I can't wait to drive this thing at 15-20lbs. lol
How should I go about triple checking my timing.
Garrett T3 .63 A/R
Bc Stage 2 Cams
Z32 Maf
10lb Tial Wastegate
Open Downpipe(blah)
Greddy Type S Bov
Enthalpy Rom Tuned
Garrett T3 .63 A/R
Bc Stage 2 Cams
Z32 Maf
10lb Tial Wastegate
Open Downpipe(blah)
Greddy Type S Bov
Enthalpy Rom Tuned
I'd first start with putting it at tdc and making sure the cams are pointed in the correct direction, then double check where the distributor rotor is pointed at in the cap.
LOL.I did that...grrrrrrrrrrrrrr
Garrett T3 .63 A/R
Bc Stage 2 Cams
Z32 Maf
10lb Tial Wastegate
Open Downpipe(blah)
Greddy Type S Bov
Enthalpy Rom Tuned
Garrett T3 .63 A/R
Bc Stage 2 Cams
Z32 Maf
10lb Tial Wastegate
Open Downpipe(blah)
Greddy Type S Bov
Enthalpy Rom Tuned
dude i have the same problem.... stock s13 ecu did n60 maf and 370 injectors and car floods itself so it wont idle or crank up... i hooked safc up and turned to neg 30% and its better but not right still.. i can unplug all my injectors and fire the car then replug all them in and hold throttle open and it will start and i have to keep it running with my foot.. i am very curious how urs turns out good luck..
i found out the problem...the two white wires on my maf were cross wired..it was honest mistake..check your maf wiring
Garrett T3 .63 A/R
Bc Stage 2 Cams
Z32 Maf
10lb Tial Wastegate
Open Downpipe(blah)
Greddy Type S Bov
Enthalpy Rom Tuned
Garrett T3 .63 A/R
Bc Stage 2 Cams
Z32 Maf
10lb Tial Wastegate
Open Downpipe(blah)
Greddy Type S Bov
Enthalpy Rom Tuned
