sr20det swap
Old Nov 18, 2010 | 08:46 AM
Jared Noriega's Avatar
Default sr20det swap
I was praying i would not have to post here...
engine swap complete.
all fuses getting power.
no dial on ecu to run codes.
power to everything.
fuel pump runs... no spark, motor is trying to start and cant.
s14 sr20det (kouki) into 96.
I love my honda, when it pressure washes my nissan.
Build threads
S13 coupe
https://www.tamparacing.com/forums/n...ht-purple.html
Kouki
https://www.tamparacing.com/forums/nissan-builds-projects/688726-kouki-project.html
Old Nov 18, 2010 | 10:36 AM
NeedCAforS13's Avatar
TOTALLY AWESOME.
Fuel lines backwards?
Did you mess with the mechanical timing or the crank angle sensor?
What do you mean by "trying to start"?
(O=O/-ROUGH WORLD-\O=O)
Old Nov 18, 2010 | 12:51 PM
DSMSpoolin's Avatar
Judge Fudge
All grounds hooked up correctly? check your injector grounds. Also check the ground on the back of the motor, alot of people overlook it. If it isnt hooked up just ground it to the strut tower and your good to go.
Many cars: Sold
1990 black top SR 240sx Coupe: Current
They use shitty skylines like this as taxi's in japan
Old Nov 18, 2010 | 03:00 PM
supreams14's Avatar
If theres no spark, I would start by checking to see if theres power to the coil packs. Then work your way back to the ignitor than the ecu.
Old Nov 18, 2010 | 03:19 PM
-Mike's Avatar
Formerly IThaJokaI
Neil, your sig is huge and annoying.
My ground on the back of my motor isn't hooked up but it runs fine?
I would look at your CAS, then coil packs, if they arent grounded they wont work.
Old Nov 18, 2010 | 09:14 PM
Empire's Avatar
buildin' it
that
i've noticed the ignitor is a rather common issue
(i mean, beyond not being grounded)
Old Nov 19, 2010 | 05:56 AM
mewantkouki's Avatar
no
yeah, if you did a battery relocation and didn't fuse the positive terminal you might have blown your ignitor chip.
