S13 differential choices, anything stronger than a 300ZX Diff available?
Old Nov 14, 2010 | 01:34 AM
espacef1fan's Avatar
Default S13 differential choices, anything stronger than a 300ZX Diff available?
Like the topic says, are there any stronger differentials available for the S13? Has anyone swapped in Ford 8.8s or anything like that? I'm looking at trying to hold back a 400-500RWTQ V8.... and not in a 240...just using a 240 rearsubframe...
Old Nov 14, 2010 | 05:51 AM
EludeR's Avatar
The Z diff should be able to handle that (R230).
Old Nov 14, 2010 | 11:56 AM
Z28ricer's Avatar
Doesnt see what you did
To use the R230, he'll need the complete Z32 TT rear subframe I believe, but yeah that would be the strongest choice.
Old Nov 14, 2010 | 02:35 PM
Empire's Avatar
buildin' it
yeah man, the z diff ought to handle that without any issues...
...it isn't a 240, but a 240 subframe...
I'm curious, what is it?
Old Nov 14, 2010 | 04:00 PM
Z28ricer's Avatar
For the record, im pretty sure a ford 8.8 would technically be a downgrade from a R230
Old Nov 14, 2010 | 04:18 PM
LongFellow's Avatar
Please hold...
An R200 will hold 500ftlbs. I'm pretty sure the AMS 1000hp S14.5 had a welded R200 and it lasted as long as the car did.
Team White Car 2010
Old Nov 14, 2010 | 05:00 PM
Z28ricer's Avatar
Quite a few people have broken the output's to lots of R200's
The Q45, GTR's, and Z32 use larger outputs, which are notably harder to break.
Old Nov 16, 2010 | 12:22 PM
89b20crx's Avatar
zeethirtytwotee-teeeee ft
a friend of mine's getting a armada rear diff. for his z. he's looking to put 1,000+ hp to it. should be the r230.
here's one of the best writeups i've found on it.. learned a lot myself
Differential / CV / LSD / HP / Torque / R160 / R180 / R200 / R230 / Diff Mount - HybridZ
however the armadas r230 diff is like a 2.9 gear ratio
'94 300zx twin turbo
'90 honda crx
Old Nov 16, 2010 | 01:18 PM
sameo2's Avatar
infiniti tech
^^That's correct,,z32 diff wont fit on the stock s13,s14 subframe.
Old Nov 29, 2010 | 12:04 PM
sullivanracing06's Avatar
kazz 1.5 way and dss stg 5s
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
