idling problem
coolant temp sensor
I found it out, it was the IACV, I worked on it last night, but satursay, A/C was blowing snowflakes, woke up Sunday and its only blowing air... Sometimes I hate 240s. Its always a on going process
It could have been a leak.
could be a bad compressor.
could be over filled and the pressure switch won't let the compressor kick on
could be a bad pressure switch
could have cracked the line when you bumped it with your arm when working on the IACV.
could have tiny unicorns dancing in your evaporator
