uhh turbo leaks oil help!
sr20det
its not the feed line to the turbo or bango that goes to the block. it not even the return oil line that goes back to the oil pan. that might be it but its in there good. idk i need help what else could be the problem that the turbo could be leaking..
seriously?
maybe teflon tape and duct tape is how it works in the Honda world with civic "hatchys" but here in the nissan world, one of the few things to withstand turbo heat is ceramic coating...
try again......
OP, remove turbo/mani, inspect all lines, fitting and seals.... worst comes to worst, clean everything all up real good, put it all back together, then go for a drive, find new wet spot and then isolate the problem...
try again......
Teflon tape will melt. It's a temporary fix.
Melting point of teflon is 342C, that will last until your car warms up and you start cruising, lol.
Epstein's little brother.
Car Specs:
White 95 Nissan 240sx SE SR20DET w/ 360whp
Red 2005 Nissan Sentra Spec-V
Human Specs:
Electrical Engineer
Car Specs:
Human Specs:
Electrical Engineer
