S13 electrical issues... anybody had this?
My first Nissan ever... 92 240sx.
So everything is pretty much in order with the car except a few bugs. I haven't spent anytime investigating for myself yet, just thought I'd throw this up, maybe it's common.
I step on the brakes and everything comes on as if I turned my lights on (except headlights).
Also, occasionally after I've had the headlights on, the driver's light stays on when I shut them off. I hit the dimmer switch and it goes out after the high beams flash.
ok, so while I was installing the clutch and brake pedals, I found the culprit... a broken brake light switch. The brake light issue is gone, but the headlight issue remains. I think the light/signal switch is garbage.
anybody have one?
anybody have one?
^No, I was wrong... the problem persists.Yes my headlight motors do not work.
I think I also have a faulty multi-switch (turn signal/high beam) If I fiddle with it, the drivers headlight comes on/off. Maybe both issues are related
Still an open issue guys, any suggestions?
