S13 electrical issues... anybody had this?
Wait... you paid $85 for that??? You probably could have gotten one here for $5. I probably would've given away my extra.
i just cleaned mine because my headlights wernt getting power... works great now. it could be the contacts not being pushed asfar and the force of stoping making them get contact
Originally Posted by Empire oh no. another ass hole 240...
Thanks guys...
I installed the new multi-switch today and...
viola!
It fixed all my issues, not only that but now the headlights go up and down again too.
wasn't even expecting these results, but everything works as it should again.
So, for you guys seeing the same problems, try replacing the headlight multi-switch.
viola!
Yep, it cured all of it. The brake light circuit is integrated with the turn signals, that way the turn signal will still flash when you step on the brakes... so it makes sense that if that switch was grounded somewhere inside, it would power the circuits it was grounded to when you activate the brake light switch. That was my theory anyway, and must be somewhere close to accurate since replacing the switch worked.
