NEED HELP! rb25det high idle
Old Apr 26, 2010 | 12:25 PM
  #21 (permalink)
David48's Avatar
I <3 usdm
Wasn't trying to be a dick. I miss-read your post. I thought you didn't know what tb means. My bad
Potato
shit got all davided up.
Old Apr 26, 2010 | 12:26 PM
  #22 (permalink)
AWD4g63's Avatar
if you dont have any usefull information please dont post on my thread. im trying to find out important shit here. im not looking for posts from d-bags.
Skyvia - The Best of Both Worlds
Old Apr 26, 2010 | 12:34 PM
  #23 (permalink)
David48's Avatar
I <3 usdm
wtf? If anything you're the one being a douche. I simply mis-read your post. There's no need for you to be a dick.
Potato
Old Apr 26, 2010 | 12:37 PM
  #24 (permalink)
NeedCAforS13's Avatar
TOTALLY AWESOME.
lol, really? sounds like you're the douchebag.
I mean don't get me wrong, I'm all for telling David he's a moron most of the time, but it's pretty clear he just misread what you were asking.
(O=O/-ROUGH WORLD-\O=O)
Old Apr 26, 2010 | 12:38 PM
  #25 (permalink)
AWD4g63's Avatar
maybe you shouldnt jump the gun and act like a know-it-all. i appreciate your attempt at trying to help out and all. but if you dont read everything correctly then how can you expect to give somebody reliable information?
Old May 11, 2010 | 02:27 PM
  #26 (permalink)
BluRRboSi's Avatar
35.5 psi, stock sleeves
I had a gasket go bad on my rb25 when I was running the stock intake manifold. The 6 ring rubber gasket that goes between the 2 pieces of the intake manifold was slightly torn causing it to idle high as hell like you are describing.
Check that area with your hands while the car is idling. Check good.
PUREBRED PERFORMANCE
Fabrication & Tuning Services
813-451-7547 or 813-712-0202
Www.PPETUNED.com <~~ WEBSITE
Curious on honda/acura Ecu Chipping and dyno tuning? Call or visit the website above. Hondata/Neptune/Ectune/Crome Pro. Tuning available for most other systems and platforms as well. DYNOJET
Old May 11, 2010 | 03:39 PM
  #27 (permalink)
AWD4g63's Avatar
the car has an isis intake plenum with a cometic gasket. ive checked vacuum leaks and sprayed ether by all the gaskets and vacuum lines and the idle doesnt change. so im thinkin my aac motor is just shot
Old May 11, 2010 | 05:52 PM
  #28 (permalink)
Adrreil's Avatar
J.R.D
Stock RB vs Q45
If there is extra stuff on the right side of the Q45 where that little whole is you need to take that stuff off. It's high idle stuff that needs coolant to run through it unless it's removed. If you search around there should be a thread somewhere on how to take it off.
The TPS is normal. I'm pretty sure the front part is for cruise control. I think. but that's how mine looks too.
Old May 11, 2010 | 08:35 PM
  #29 (permalink)
S13_JDrift's Avatar
yeah there nothing that goes to the plug on TPS, so dont worried about that.
check witch TB you have
Old May 12, 2010 | 02:12 AM
  #30 (permalink)
AWD4g63's Avatar
thanks for all the help guys. i didnt realize the difference in size of the tb's was that big lol. but i definately have a stock tb. and i think the idle problem is the iacv. because if i unplug the plugs on it the idle doesnt change at all. but if i pinch off one of the 2 hoses going to it the idle drops. so i think the aac motor is bad. anybody know where to get a cheap rb25 aac motor?
