SR lagging at WOT...?
damnit, I think I have the same problem -__- fuel pump hasn't been touched since the swap which was probably about 5-6 yrs ago...
thank God I looked at this thread lol
- Noel
Listen to Trance, House, and/or Progressive music? Check out my mixes, I think you might like 'em
Vehicular Résumé
'93 Nissan 240sx Hatch (Sold)
'91 Nissan 240sx Hatch (Sold)
'91 Nissan Maxima SE (Died [Blown Tranny @ 250k+ mi])
- Noel
Vehicular Résumé
I literally changed out everything that had to do with the motor, I mean everything.Checked all wiring. I compression tested it also and it was perfect across the board.
Only things I had left were:
Knock Sensor
02 sensor
But before I did that, I was like hmm let me just check the fuel pump. Sure enough I pull it out and it is green/black. I dont think it was ever changed. Put in my walboro ran like a fucking champ.
Knock Sensor
02 sensor
had a similiar issue with my sr. If I full throttled the car would break up like a boost leak. Did a boost leak test an it was all good. Checked voltage to cas, tps, an maf all good there. Changed fuel filter an plugs made a lil difference but still was breaking up on full throttle. I pulled the harness and part of the harness going to the coil pack harness was fried up, replaced the section an haven't had any issues yet, gl
Matthew "RudeBoy" Nugent 2/03/88-04/01/09
Knock Sensor
02 sensor
Knock Sensor
02 sensor
You jokers realize that a $50 fuel pressure gauge would have saved all this trouble, right?
^More like 25 bucks. If people would look back a few pages I posted links to a good fuel pressure gauge in mid 2009.. lol
But I definitely agree with you. You guys should just spend 25 bucks on a gauge. It's a good investment.
https://www.tamparacing.com/forums/nissan-infiniti-tech/569557-those-need-fuel-pressure-gauge.html
Can't get the link to work so copy and paste it.. lol
word! still havent checked boost leak, but i was told to check base ignition timing. whats that? lol and also when i unplug my fan from my fuel pump fuse location, the motor idles up a bit, and sorta "cleans up".. and this is because im running my fuel pump directly from acc power at ign because it didnt work when i turned the key on originally. so basically here exactly my deal:
it bogs real hard at heavy acceleration, especially after 2500 or always at wot. and when im just cruising at like 2500 or higher, it will randomly bog, like i can watch the vacuum go from 10/11 down to 1, and then it comes back up to 10/11 after a few seconds. the way it breaks up, im thinking its something fuel related.. any suggestions?
and, i put my stock pump in and it made it worse, way worse. but i also pumps VERY softly, is that normal?
live to love the RWD.
89 seafoam coupe w/ SR20 and more- FOR SALE<- click
FAX
______________________________
FAX
Sounds like a fuel problem if the stock pump made it worse. Were you driving hard with a stock pump? How was it at idle with stock pump?
Get a fuel pressure gauge. Sure you have the correct firing order and timing?
firing order is def right, and i timed it according to the fsm, just havent gottem a light on it yet. and i could hardly even accelerate with the stock pump. im almost thinking im not getting 12v to the pump... because ill say, i had my turbo timer wired into my ignition harness, which is where i ran my fuel pump power, and it was smoking so i unplugged it. im thinking theres to much current pull.. but i dont have a fucken volt meter here, this blows.
FAX
FAX
