s13 Bogging help
Ok heres the story, Ive been running around with a bogging car for a while, checking the ignition system, maf, vac hoses, ect ect ect. Anyway, as it turns out it appears to be an ecu problem because when i reset the ecu the car runs like new.
So here are my options
1: Replace ecu and waste money cause its probably something else causing the ecu to detune
2: figure out what really is causing the problem
Anyone have any idea what could be causing this?
possibly o2 sensor?
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
