Rear suspension is fucking up
Old Feb 23, 2010 | 07:00 PM
Petitt's Avatar
The Riot Society
Default Rear suspension is fucking up
Forget the fact that its pretty bouncy, there is this loud, god awful noise coming from the rear passenger side wheel well. The sound changes with speed so i was thinking it was rubbing, but I checked and thats not it.
To make things even more odd, it all of the sudden stopped like 2 minutes away from my house? Car needs aligned (pulls right) so could that have anything to do with it? The whole trial and error type of fixing is out of my budget right now so any sorta help at all would be appreciated.
Old Feb 23, 2010 | 07:03 PM
cyanide's Avatar
Sounds like a wheel bearing issue or loose suspension component.
Old Feb 23, 2010 | 07:06 PM
Petitt's Avatar
The Riot Society
any specific way to check if its the wheel bearing for sure? I'm taking it all apart tomorrow and tightening everything for sure lol
Old Feb 23, 2010 | 08:32 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
yea if you can grab ur wheel while it's on the car and move in and out.
also check to see if all parts are tight
Drifting:
most fun you can have
with your pants on.
Old Feb 24, 2010 | 09:54 AM
Petitt's Avatar
The Riot Society
Drove 45 minutes to work today and no sound at all.
Old Feb 24, 2010 | 10:54 AM
presidential's Avatar
OG Join Date: 6-15-00
YouTube - Bad Wheel Bearing on MKIV GTI
If it's doing this or makes a grinding sound when the wheel spins, it's going to be your wheel bearings.
1973 VW Squareback
1979 AMC Jeep Cherokee Chief
RIP Tim
Old Feb 24, 2010 | 12:38 PM
Z350man's Avatar
Blah Blah Blah
if you have coilovers and you dont have the coil nuts tight it will cause vibration.. i would check that its easy and fast fix if it is the issue.
