Car has Power even when the key is out?
Old Feb 10, 2010 | 06:43 PM
ZenkiLB's Avatar
Finally out of 240 scene!
Default Car has Power even when the key is out?
ok well i recently got a hatch shell and i swapped my ka from the vert into it, and when you turn the key everything gets power but when you turn the key and take it out everything still has power, it was even doing this before the motor was in and it was just the battery help me lol
No more POS 240's
Old Feb 10, 2010 | 08:09 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
i had the same problem a while back it ended up being the ground wires by the pass side fuse box were not hooked up to get a ground,so check all your grounds..
with mine if i turned the key on everything would work and when i would go to turn it off it would stay on,i had to start the car then shut it off for it to shut everything off.
Drifting:
most fun you can have
with your pants on.
Old Feb 10, 2010 | 08:18 PM
ZenkiLB's Avatar
well all the grounds are connected besides the one right under the fuel rail
ill try it again tomorrow and ill makesure everything is hooked up right,
No more POS 240's
Old Feb 10, 2010 | 08:49 PM
Z28ricer's Avatar
Doesnt see what you did
Some idiot failed at a turbo timer install and now the ignition switch wires are melted together ?
Old Feb 11, 2010 | 03:26 AM
Epstein's Avatar
Retired
A bad ECU can do this, too.
Old Feb 11, 2010 | 03:45 AM
ZenkiLB's Avatar
ill swap out my ecu from my vert i guess,
and z28ricer what does a turbo timer install have to do with my problem?
No more POS 240's
Old Feb 11, 2010 | 06:09 AM
younghatchowner's Avatar
i have the same problem..idk
Carisma Built Ka(BC Valve, Springs, Retainers, JE Pistons, Eagle Rods,Cometic HG, Supertech Intake Valves, Supertech .5+ Exhaust Valves
Garrett T3 .63 A/R
Bc Stage 2 Cams
Z32 Maf
Injector Dynamics 725cc
10lb Tial Wastegate
Open Downpipe(blah)
Greddy Type S Bov
Enthalpy Rom Tuned
Old Feb 11, 2010 | 09:45 AM
Z28ricer's Avatar
Turbo timers retain the power when you turn off the key like you didnt turn it off, if the wiring is messed up it could be the two power wires melted together, retaining power full time.
I didnt think he meant the car just stays running, rather the power to everything stays on, like the switch wasnt turned off at all, I thought when the ecu ground is toast the engine just stays running but the rest of the power is off ?
Old Feb 11, 2010 | 09:50 AM
wickedklown's Avatar
check the back of your ignition switch and see if there is a build of of corrosion between the terminals
As for the 12-pack, I noticed your 18...be careful cause a 12-pack of those energy drinks and you'll be shaking like a dog shitting razor blades.
Old Feb 13, 2010 | 11:29 AM
obituary's Avatar
TR OG
maybe stuck relay?
1972 nova ss
89 240 sr20det
2002 chevy 1500 truck
