S13 sr swap help
I bought the swap and got it in the car. I did the whole thing but when I went to start it up for the first time, it just wouldn't start. First of all I had to relocate the battery to the trunk and I don't know if I did it right. something is wrong with the plugs that go to the fuse box. ( the black and green ones that plug into the red positive terminal.) when I connect the battery it does one of two things:
1. the interior lights come on and when you go to turn the key to start the car you hear a click. no power at all. you troubleshoot the positive wire and i lose power at the black plug. if i unplug it i will have power there. i tested all fuses in the box and all but fog lights are good. if i mess around with the fuse box the lights will come back on.
2. after playing with the fuse box ( just moving it around and testing fuses ) car will crank and crank but no start. I have fuel and spark. brake, door, and oil light remain on constantly ( even when door is closed and brake is off. )
Has anybody ever had this problem? please help! I want this thing to run so bad!
