S14 Zenki/Kouki question
Old Oct 19, 2009 | 06:01 AM
Epstein's Avatar
Retired
Originally Posted by drifthappy
Ill post it anyways. S15 cluster into s13
Figuring out how to understand the FSM literally opened the door for me to completely understanding any Nissan. To put simply.. all the circuits in your cluster are 12volt and are complete circuits. You just provide the positive and negative for it at specific pins, which the FSM explains to you!
You have Two pins for power (one constant for the clock, one ignition for the cluster) and one pin for ground. Then, for example, you tap into your left blinker right under your steering wheel for pin 21, then tap into your left blinker for 29, then ground pin 28 to the chassis. And that's it.... you now completed the blinker circuit and have working blinkers/hazards on your cluster.
Believe it or not. The gauges are even easier. The RPM is one wire directly from the ECM (yellow/red). The Fuel gauge is one wire directly from the fuel pump (the green wire). The water temp is one wire directly from the sensor. And lastly, the speed is also directly from the ECM, but I couldn't wire this one since I don't have the ABS system or the VSS.
I used the terminals from a ECCS harness. So slice one up and take a bunch of wires out of it. Then start making your own harness. What's so awesome is that... I probably only wired in.... 15-20 wires to the cluster to get only what I needed to work (rpm, gas, w. temp, blinkers, high beam, hand brake, check engine, oil pressure, gauge illumination, and air bag. If you don't ground the air bag terminal, the air bag light will stay on forever.). There are 64 pins, half of which aren't used unless you have the Hicas system for example, or an Automatic tranny. Last, advice. You should have about five ground wires coming out of the cluster, it's important that you ground each wire seperately, at least an inch apart. The current could travel backwards in the wire and short a circuit (don't worry though, there are diodes built in to the circuit board to protect it from damage).
^ this. I never understood why people thought wiring was so hard. Power, ground, signal.
Old Oct 19, 2009 | 12:43 PM
Blackzenki82's Avatar
(OO\____/OO)
sooooooooo.......... yeah, Kouki cluster will work in a Zenki, just more BS than i want to go through to make it happen... i can get a Zenki JDM cluster for the same price as a JDM kouki, just the kouki unit was more redily available...
thanks guys!
oh, and komron, i'm sure you hear this a shit ton, but nice ride bro... i was aiming to get a S14 Silvia a month or so ago, but decided against it... you though, have reinspired me to get one, at a later time... nice work on it too, very clean...
Originally Posted by sean1
Shit'll buff out.
Old Oct 19, 2009 | 07:55 PM
komron's Avatar
drifthappy, i didnt say it was impossible, i was saying its more than just doing a couple of wires lol.
blackzenki82, thanks. i forget your name (im horrible with names) but it was really nice talking with you. when youre ready to buy one let me know. i think i still know of one available. to be honest tho, love 14's, but i want to get a chassis that was never available over here. sucks cuz at the time i bought my car, prices were still really high on the vehicles. with all the work and parts on my car, in the market now, i could have had an S15
