Overheating problem
Old Sep 6, 2009 | 12:11 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
maybe your coolant temp sensor is fucked up?
Old Sep 6, 2009 | 12:42 PM
Davetheslave's Avatar
guess Ill try the water pump once i get paid. Its definatly overheating cause it caused the radiator hoses to burst so its not the sensor i dont think.
Old Sep 6, 2009 | 01:09 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
seems like you have a bit of air in your system.
Old Sep 6, 2009 | 04:28 PM
mewantkouki's Avatar
no
Check your heater core, and heater hoses. Remove the thermostat and fill the car with 50-50 coolant. Bleed the heck out of it on an incline. If that doesn't work, you either have an occlusion in your coolant passages, headgasket is going, or the water pump took a shit. Is the car eating coolant?
Old Sep 6, 2009 | 04:34 PM
youngbrazee1's Avatar
Mine is eatting or coolant. what does this mean
Old Sep 6, 2009 | 05:00 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
if you're burning coolant its a leak or the headgasket.
Old Sep 6, 2009 | 05:01 PM
  #17 (permalink)
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
if his heater core was fucked up he would smell it.
Old Sep 6, 2009 | 05:51 PM
  #18 (permalink)
Nah its not eating coolent
Old Sep 6, 2009 | 10:19 PM
  #19 (permalink)
Empire's Avatar
buildin' it
my money is on the water pump... my old motor did the exact same thing... it would over heat at idle, but be fine once I got it moving. The increased air flow masked the fact that there wasn't enough coolant flow...
and just to cover all of the bases, it might also be the clutch on the fan... it might not be engaging like it should and therefore not pulling enough air...
Old Sep 7, 2009 | 08:05 AM
  #20 (permalink)
jizmogloben's Avatar
ive had the fan clutch do that to me before too
