clarifications on specs!
Old Mar 7, 2002 | 10:51 AM
dan's Avatar
dan
Get the fuck off my lawn
ok ive been pondering these claims and ill ask here first to see what people have to say.
ok stock s13 sr20det has 370cc injectors. the stock garrett t-25 is NOT the same as a mitsu t25 obviously since stock dsms can run their t25s up to like 18 or 19psi stock.
now
14psi is the accepted maximum boost level you can run because is it:
a) 370cc injectors max out after 14psi?
b) t25 becomes inefficient at 15psi starts blowing hot air or
c) is it a combination of both?
please clarify this for me because i have heard charles (boosted240) runs more psi on stock turbo and injectors? and i have heard of people running 16psi with upgraded injectors but stock turboes as well as people running higher than 14psi with stock injectors but upgraded turbo.
which are true
thanx
dan
edit: not ragging on you charles your input is appreciated as well because someone asked me about these things and told me that you were running higher with both inj. and turbo stock still. how do you do it?
Old Mar 7, 2002 | 01:07 PM
2wdBlazer's Avatar
Vechicle Whore
If you want it to live a long time keep it like 12 psi and under. DSMs run their boost high beacause the turbos are a dime a dozen for Mitsu. DSM t-25s die all the time for that reason. Nissan t-25 cost more. They are also not very efficient at levels above 15 psi. Lots of hot air. Ansewr your Question?
-Kris
Current Projects:
72 2wd Blazer
2013 BMW X5
2008 Chevy TBSS awd
Old Mar 7, 2002 | 02:15 PM
cyanide's Avatar
go find a compressor map of a t-25. or www.turbofast.com.au and find the calculators
Old Mar 7, 2002 | 04:18 PM
Handi Man's Avatar
Chairborne Ranger
now
which are true
thanx
dan
Yes Dan I do sometimes run higher then 15psi. My boost controller is set at 15psi most of the time but sometimes it will creep to like 20psi. and one night i ran around at 20psi all night and it seemed to pull really hard even above 15psi. I mean i am sure that the turbo becomes worthless after like 16-17psi. but until i get my AVC-R i am having to deal with my boost creep.
And yea.... DSM turbos are very easy to get as apposed to the t25 on the SR20DET.
BTW... does anyone know if a T-3 from a z31 turbo will bolt up to the factory SR20DET manifold without any major diffaculties?
Thanks
Charles, originally "Boosted240"
www.facebook.com/CPRegister
03' Silverado 2500HD 6.0L Ext Cab w/Wheelchair access conversion by Ryno Mobility
Originally Posted by PoppaSmurf
well like i said in another thread, if charles hasn't pissed you off, or gotten on your nerves, it means ya didn't know him that good
Old Mar 7, 2002 | 11:04 PM
dan's Avatar
dan
thanx man i know jay whitely says that above 14psi it gets inefficient he knows his stuff. ill see if he has anything to say on it do u know about the injectors? and what boost controller are u running??? be careful on that creeping!
oh here this might help with your needs. the T3 will fit because it utilizes a t25 flange they are the same.
https://www.tamparacing.com/hebb/showthread.php?threadid=16758
Old Mar 8, 2002 | 08:19 AM
Chismoe's Avatar
Craving Boost
I always thought the T-toosmall was the same on DSM and on SR motor. Its the same turbo just for some reason the SR cant hold the boost as well as a 4g63...at least thats what the case appears to be to me.
Heres my experience with the turbo:
15-16psi is as high as you can go on 93 octane gas. Above that it will just blow hot air.
Now go get some 100+ octane gas
crank the boost to like 21-22 (wont hold drops off to about 17) and there is a night and day difference. The turbo will still pull on the top end with better gas. Of course with my AFC I can lean it out with better octane and run alot better.
Basically my car goes from mid to high 14s from a roll on pump gas to low 14s on race gas
Of course DSMs have 450cc injectors stock(5speed) so we can support higher boost easier.
NOt sure how much that will help but just thought Id give you my end.
Oh and you guys are lucky in that you run low 13s with the t25 exhaust and intercooler. Strap on a Forced Performance Big28 and you could reach 11s easy with traction gaskets fuel and the other supporting mods.
Old Mar 8, 2002 | 04:16 PM
dan's Avatar
dan
thanx jay.
i do plan on using proabably the greddy or blitz or maybe even apexi downpipe along with a custom welded test pipe back 3 exhaust. it really depends how long it takes for my money supply to build up because i might just go straight to upgraded turbo by then but it will depend.
thanx
Old Mar 8, 2002 | 09:28 PM
Handi Man's Avatar
Chairborne Ranger
Yea...
I have a custom 3 downpipe w/o a cat going into an Apex i N1 (which i removed the resonator from) so i have a pretty strait flowing exhaust.
Dan... as for the boost controller it is a Home made one thats just like the manual one that Turbonetics sells You know.. the Air Compressor regulators. However i will be putting an AVC-R on as soon as it arrives at my door. (waiting on the guy to ship it). And thanks for the info on the T3.
