VQ35 Engine Swap w/ stripped and tuned ECU
Old Aug 3, 2009 | 08:30 AM
180SX's Avatar
Default VQ35 Engine Swap w/ stripped and tuned ECU
So we finally came up with a much better solution for doing a VQ swap than the AEM route.
These motors are relatively cheap and can usually be had with trans for around $1000. The downside was you either had to have a half a cars worth of crap to make them run electronically or buy a AEM, harness for $2650.
I now offer harness service for $500 and ECU tune / security / all unnecessary electronic stuff removal for $450. The only thing you have to source is a e pedal out of anything newer than 2003+ nissan.
Martin S.
http://www.youtube.com/watch?v=YtcCPtLBXvI
Old Aug 3, 2009 | 08:36 AM
240Cyanide's Avatar
Function is my form.
so how much for engine swap+ecu?
Old Aug 3, 2009 | 11:31 AM
Epstein's Avatar
Retired
Great work, Martin! Finally an electronics package to complement the hardware swap packages that are out there!
Man, if someone only made a Z32 5-speed kit for the VQ, I'd be all in!
Old Aug 3, 2009 | 11:41 AM
EludeR's Avatar
Whats wrong with the Z33's transmission ?
Old Aug 3, 2009 | 12:20 PM
JDM Status's Avatar
Original status
probably because of the 6 speed vq tranny
Tsuda-Ichi
Old Aug 3, 2009 | 12:28 PM
Epstein's Avatar
Retired
Or a 6-speed would be nice. Whatever's cheap!
Can you speak about a tach signal and compatibilty with the stock cluster? Getting the speedo to work is well documented, but I don't hear about the RPMs much.
Old Aug 3, 2009 | 12:34 PM
McLovin''s Avatar
Offset Is Everything
well, in the post he mentions motor and tranny for about 1000. So what solutions does Fever have for mounting, drive shaft, and shifter placement? This is really neat, however, I don't know how paranoid I would have to be of not having a key start, or any of the other "security" accessories.
Old Aug 3, 2009 | 01:16 PM
180SX's Avatar
rpm is easy... i did it on nick hogans 350z for his SAFC.... just buy the msd tach adapter from COP signal.. i have the part number... and its only like $40
martin
Old Aug 3, 2009 | 01:24 PM
Ph34r's Avatar
ΔxΔp ≥ h
That setup is amazing Martin. Can't wait for someone to drop one in. I'm gonna go buy a few scratch offs and see if I can be lucky enough to win enough to get the swap in my hatch.
Old Aug 3, 2009 | 01:42 PM
Epstein's Avatar
Retired
Well obviously you'd use a key to start it. It's the same amount of security as any KA or SR. Ignition power and any pre 2000-ish motor will start.
