fuel pump question
Old Jun 9, 2009 | 03:59 PM
chask's Avatar
NEVER LIFT!!!
Default fuel pump question
i was out drifting the other day and my car died out and would not start i figued out that the fuel pump was not turning on is that becuase its broken?? or is that a relay that went bad?? where is the relay on an s14?? jw thanks alot ~~
www.sundayslide.com
SUNDAYSLIDE Floridas Underground Drift Culture
Media coverage for Florida's Events, Cars, Drivers, Tracks and much more!!!
Old Jun 9, 2009 | 04:12 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
there is a fuse box on the pass side under the hood should say fuel pump relay..
and do you hear it turn on or no?
Drifting:
most fun you can have
with your pants on.
Old Jun 9, 2009 | 05:46 PM
chask's Avatar
NEVER LIFT!!!
naa it turns on but really lightly it like clicks and sounds like someone is sucking air threw a straw
www.sundayslide.com
Old Jun 9, 2009 | 06:39 PM
A-ron's Avatar
might be ur fuel filter could be clogged.
and ur fuel pump humms the relays click
Drifting:
with your pants on.
Old Jun 9, 2009 | 07:59 PM
chask's Avatar
NEVER LIFT!!!
yeah its hard to explain like when i turn the before you can hear the whole fuelpump turn on no problem now i cant hear it at all.. and when we took it out of the tank and tried to turn it on it would make noise but it was really really dead sounding... it sounded like it was sucking air but not very good... but my friend said when i turned the key he could feel power though the wires... soo im guessing if im getting power back there the pump is just bad.. ??
www.sundayslide.com
Old Jun 9, 2009 | 08:04 PM
A-ron's Avatar
hold on he feels power in the lines??lol
so you pulled the pump out and turned it in and it sounded bad well it is sucking in air which is bad.
and if it turns on it should be good.
if you pull the fuel lines off the fuel rail turn the key forward if no fuel flys out could be bad pump or filter so check it out..
Drifting:
with your pants on.
Old Jun 9, 2009 | 08:26 PM
chask's Avatar
NEVER LIFT!!!
yeah well listen the pump is out of the tank thats why its sucking in air i have no choice really and like i said you can hear it click on (the pump) but its very quiet yeah its turnign on but its not as loud as it use to be... you can scream in my ear while i turn on my fuel pump and i would hear but that was before.. now i cant hear shit... you have to pull the pump out of the tank to hear anything...
and thats what he siad he felt the wires where hot soo idk,,
www.sundayslide.com
Old Jun 9, 2009 | 08:30 PM
A-ron's Avatar
well then replace the pump maybe it did take a shit
Drifting:
with your pants on.
Old Jun 9, 2009 | 08:43 PM
chask's Avatar
NEVER LIFT!!!
yeah i was just trying to ask if anyone knew the issue before i spend the money on a pump for nothing seince i dont make much money these days
www.sundayslide.com
Old Jun 9, 2009 | 10:33 PM
chome's Avatar
Will sleep for food.
I have a stock S14 pump you can try out.
