I did a compression check and car wont start
Old Mar 22, 2009 | 09:40 AM
Zenki Sean's Avatar
JDM Abuse
Default I did a compression check and car wont start
i recently did a compression check with it being 175-180 across on my 1995 s14 240sx because i was getting smoke coming out of my exhaust when i leave a stop light or stop sign and it dissipates and doesn't smoke until i sit at a light or take off only when sitting. this is the reason i did a compression check. I also have an issue with starting sometimes and the symptom is it starts fine sometimes and other times it takes 2-4 seconds longer to fire up, - thus being another reason to check the condition of my cylinders.I have been running 93 octane for a while now. i did the compression check with removing spark plug wires and next plugs. after all of them were removed i checked the compression of each cylinder. i kept the plugs in the correct order and replaced them in the correct spot of which they came out of since the compression was good. i waited like 10 min. to let the fumes clear out of the cylinders to crank it over and it wont start.
1989 Nissan 240sx KA-T-Traded
1990 Nissan 240sx Sold
1989 Ford Mustang-Traded
1995 Nissan 240sx-Totalled R.I.P
1994 Dodge Ram-sold
1995 nissan 240sx se - daily driver
2003 Mitsubishi Eclipse GS-Wife's DD
Old Mar 22, 2009 | 09:45 AM
omgwtfbbq!'s Avatar
I race sailboats
You didn't disable the fuel injection while you were cranking it with no plugs?
Bitches don't know about the twin turbo
BLACK FENDER PART OUT
Old Mar 22, 2009 | 09:50 AM
Zenki Sean's Avatar
JDM Abuse
that was my mistake i couldn't find the fuel pump relay so i did the check and waited for the gas to dissipate before putting the plugs in and i blew out the cylinders with an air compressor just to make sure it was clear of fuel I'm sure it was flooded. last night i left the plugs out and this morning i put them back in which should have been plenty of time for it to clear out .
1994 Dodge Ram-sold
Old Mar 22, 2009 | 11:47 AM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
well are you getting spark/fuel.
why didnt you unplug the dizzy when you were doing the test???
so you were just throwing sparks everywhere when you were doing the test thats no good. you could have fried ur dizzy or even worse.
and it dumping fuel in while you were comp testing it you should be fine i never pull the fuse.. find out if you are getting spark and let us know
Drifting:
most fun you can have
with your pants on.
Old Mar 22, 2009 | 12:14 PM
Zenki Sean's Avatar
JDM Abuse
ok thanks i just bought a new set of plugs also
1994 Dodge Ram-sold
Old Mar 22, 2009 | 12:17 PM
Zenki Sean's Avatar
JDM Abuse
how could the dizz fry im not understanding how that could have happened
1994 Dodge Ram-sold
Old Mar 22, 2009 | 12:23 PM
Matt Vassallo's Avatar
lifelong learner
plug in cam angle sensor lols
rest in peace tim.
Old Mar 22, 2009 | 12:30 PM
Zenki Sean's Avatar
JDM Abuse
everything is plugged in im starting to think that it could be a bad dizzy but i dont know what goes out in these things i took the cap off and the rotor looks fine
1994 Dodge Ram-sold
Old Mar 22, 2009 | 12:32 PM
ridinsolo/nat's Avatar
you need a new head the one u got sounds to be f in the j
Old Mar 22, 2009 | 12:35 PM
Zenki Sean's Avatar
JDM Abuse
I know that the smoke is possibly the valve stem seals or valve guides so correct me if I'm wrong.
1994 Dodge Ram-sold
