I did a compression check and car wont start
Old Mar 22, 2009 | 12:57 PM
Zenki Sean's Avatar
JDM Abuse
i just checked for spark and im not getting any i just bought new plugs and those are the ones i just tried to use. i looked and my wires dont look all that great either one of them has a cut in the shielding and little hair line cracks in it. i think that they are the same condition that the car has been running with so probably not a factor here.
1989 Nissan 240sx KA-T-Traded
1990 Nissan 240sx Sold
1989 Ford Mustang-Traded
1995 Nissan 240sx-Totalled R.I.P
1994 Dodge Ram-sold
1995 nissan 240sx se - daily driver
2003 Mitsubishi Eclipse GS-Wife's DD
Old Mar 22, 2009 | 01:28 PM
Zenki Sean's Avatar
JDM Abuse
troobleshooting questions-------------------------
What was done to get you to this point?
1) i did a compression check by unplugging plug wires.
2) removed spark plugs ( bought new ones) iridium ix heat rang 5
3) hooked up compression gauge to each cylinder at a time with all plugs out .( compression readings came out satisfactory between 175-180.i let the plug wires hang and dangle around the exhaust area still connected to the dizzy
4) after doing compression i blew out the cylinders using a nozzle and air compressor to clear fuel and or fumes from possible flooding of engine since i had done nothing to prevent this.
5) i replaced old plugs in the correct order (didn't buy the new plugs until i found the problem) and connected the wires to the plugs
6)all systems should have been go so i started to crank the motor over until i knew it wouldn't start which was around 5-7 seconds so it wouldnt flood realy bad
Was the motor swapped, rebuilt, or a head gasket changed?this is the original motor no swap not rebuilt and no blown head gasket since the compression was near perfect
You state you have spark, fuel and compression, but how did you test for each one of these?1)i test for fuel by smelling for it i have a fuel pressure gauge and the spark plugs are wet i also hear the fuel pump turn on, i tested for spark which i don't have. 2) i tested this with putting a spark plug in the spark plug wire and holding it up against the head, block and also the bolt to the strut tower no spark at all, 3) i checked compression by a gauge previously mentioned
Did the car run before, or did you buy it in this condition?i bought the car a while back and it has ran right up to the point until i did the compression and tried to crank it over.
What other items were changed on the car?no items were changed other than buying new spark plugs to check for spark . the old ones were pretty bu boo
Answering these questions should give you a better understanding, and give you some routes to help me and you on troubleshooting thanks.
Sean
1994 Dodge Ram-sold
Old Mar 22, 2009 | 02:20 PM
asia989's Avatar
Why So Serious?
might have fried the ecu, kinda like shinmei
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
Old Mar 22, 2009 | 03:15 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
try swapping out with a friends dizzy to see if you start up. if still no spark borrow an ecu and then try again.. if all that stil doesnt work let us know
Drifting:
most fun you can have
with your pants on.
Old Mar 22, 2009 | 03:27 PM
Zenki Sean's Avatar
JDM Abuse
thats a start well here comes the gayness my car is automatic and im doing the swap asap cause i have the tranny and drive shaft and (ish) can you use a manual cu on a automatic with any concerns because i know you can use a manual on an automatic thanks for all the help guys
1994 Dodge Ram-sold
Old Mar 22, 2009 | 03:40 PM
Zenki Sean's Avatar
JDM Abuse
my ecu thew code 55- (Other Malfunction. CONSULT Terminal Required) it never did that and it still threw the other codes it use to like 34-knock sensor and 105- EGR solenoid does it through codes when its fried or is there a definite way to know when it happenes. thanks for the help
1994 Dodge Ram-sold
Old Mar 22, 2009 | 03:43 PM
  #17 (permalink)
Zenki Sean's Avatar
JDM Abuse
also does anyone know exactly what happens to the distributor to make it go bad and if there is a way to fix it instead of getting another one?
1994 Dodge Ram-sold
Old Mar 22, 2009 | 05:20 PM
  #18 (permalink)
4wheeldriftS13's Avatar
February - Ride of the Month
yeah I heard if you bang the distributor on the ground it might work again?
RIP Tim Aldrich
Old Mar 22, 2009 | 05:25 PM
  #19 (permalink)
JDM Status's Avatar
Original status
Hes cool sean (4 wheel drift),
you can leave him alone lol.
i got patted down for mari ju ana at his house too, kinda shitty,
good luck sean, hope you get it working again
Tsuda-Ichi
Old Mar 22, 2009 | 07:42 PM
  #20 (permalink)
A-ron's Avatar
hey you never know the russain way just might work...
Drifting:
with your pants on.
