Eliminating Rear Wheel Hop
Old Mar 5, 2009 | 06:20 PM
  #21 (permalink)
Superluminal's Avatar
The Cyber Brain
Originally Posted by Torrential
I agree with matt on this on tire pressure or how much I waqrm the tires up plays a big role on if my car hops when I quick shift into second third or even fourth gear.. anything under 25psi on the oil mickey setup and I would be granny shifting to avoid wheel hop. Bushings did help out a lot though.
I'd figure that since you have a bit more contact patch on lower psi, so instead of spinning, if it does give it wheel hops. It must be pretty violent on sticky tires, but with the power your car is putting out I'd assume you spin a bit more than most.
I also notice the stickier the pavement the harder it wheel hops. It's also pretty bad in the rain as well. I'm going to look into the bushing kit for the rear only, as my front end has mostly new bushings already.
Old Mar 18, 2009 | 07:41 AM
  #22 (permalink)
treekiller's Avatar
legend behind the cowl
+1 for new bushings! made a world of diffrence on my NEWISH 2006 car, I can only think about how well it'll help a car with 20 years under it's chassis.
