ka24de idle issues S13
Old Feb 3, 2009 | 04:17 PM
raptor727's Avatar
Default UPDATE ka24de idle issues S13
i have a 92 240sx dohc. its got about 130000 miles on it. nothing major, electric fan, injen intake. i am having an issue with the idle. the idle when im at stop lights usually drops to 400 rpms and goes up and down sometimes but usually sits at 400ish. idle goes up and down a hundred rpms. but it doesnt always run rough, sometimes smooth. feels like it might be miss firing. not sure. but like i said it doenst do it all the time. Spark plugs are a couple months old. the tips of the spark plugs are a chalky white color. when it is running completely smooth it idles around 600 or 700 rpms. im in the process of getting a new tps.
Old Feb 3, 2009 | 04:20 PM
IThaJokaI's Avatar
Hates cars...
vacuum leak?
Old Feb 3, 2009 | 04:25 PM
raptor727's Avatar
i havent found any leaks. but if it was a vacuum leak wouldnt do it all the time?
Old Feb 3, 2009 | 04:29 PM
xnissan240x's Avatar
Fishes more than you
just replace stuff until it corrects
Old Feb 3, 2009 | 09:55 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
turn the idle up. (screw on the throttle body.)
due to the plug being white and/or chalky leads me to believe your car isn't getting sufficient fuel pressure and is running super rich (another reason why your car could drop rpms and give you the illusion of poor firing/timing), check you injectors and have them flow tested. if that doesn't work replace your fuel filter and possibly your fuel pump. checking distributor timing also wouldn't hurt. and i doubt it, but you could be running a plugs a tad too cold.
grab some NGK V-powers (BKR5E-11) gap to .39.
Old Feb 4, 2009 | 09:08 AM
blue_eclipse93's Avatar
dum de dum
sounds like what was going on with my old 240 right before the brake booster went out.
Facebook
1993 Mitsubishi Eclipse GS - Lost - L
1990 Nissan 240sx - Totaled(r.i.p)
1991 Nissan 240sx - Sold
1990 Nissan 240sx - Sold
1993 BMW 325i - Traded
1990 Nissan 240sx TotaledTOT
2009 Nissan Sentra -
Sold2005 Yamaha R6 - Sold
2006 Yamaha R1 - Stolen
2000 Nissan Sentra - Daily Driver
Old Feb 4, 2009 | 09:14 AM
JonSUCKA's Avatar
Happened to every one of my 240's... I replace the fuel filter (5$), coil (15$), and plugs (20$) and they run fine after... either that or vacuum leak (Frizzle).. those are the first things I would check..
rusty an shitty
Old Feb 4, 2009 | 02:48 PM
raptor727's Avatar
re: jordan t
i replaced the fuel filter about 6 months ago but ill check the injectors next, but i read somewhere that if you run fuel injector cleaner that is what causes the chalk white color.
Old Feb 4, 2009 | 02:50 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
it could yeah, if its not combusting properly
Old Feb 4, 2009 | 02:59 PM
cagedeyecam's Avatar
AERODYNAMIC WHEN I FIGHT
isnt there a valve or something on the back of the intake manifold near the firewall. me and jason sink were playing with this problem before and he just turned that and it worked perfect
