s13 sohc transmission question
Old Jan 28, 2009 | 05:25 PM
redneck222269's Avatar
Default s13 sohc transmission question
s13 sohc, 5 speed manual. will a s14 5 speed transmission bolt up or a dohc s13 trans? just wondering if there are any differences. thanks for the input
Old Jan 29, 2009 | 05:26 AM
jizmogloben's Avatar
s13 and s14 both bolt right up
Old Jan 29, 2009 | 05:36 AM
xnissan240x's Avatar
Fishes more than you
What are you asking?
Old Jan 29, 2009 | 01:42 PM
i have a sohc s13 5 speed. transmission grinds in third so i am going to replace it and wanted to know if a s14 transmission would bolt right up and wiring would just plug in.. i didnt know if sohc transmissions were different then dohc transmissions. input is greatly appreciated, thank you
Old Jan 29, 2009 | 01:49 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
yea it will bolt right up. all you need to do is change out speed sensors.
the s14 speed sensor will not plug in so you need to use yours.
Drifting:
most fun you can have
with your pants on.
Old Jan 29, 2009 | 04:34 PM
ok so my speed sensor will plug right into the s14 trans?
Old Jan 29, 2009 | 05:48 PM
A-ron's Avatar
yes a size 10 wrench losen pull straight out x'2
swap tighten all done very easy. ohh it's the last sensor on the tranny it has a long ass wire going to it
Drifting:
with your pants on.
