Window Problem, Need Assistance
Old Jan 27, 2009 | 07:47 PM
+Waldo+'s Avatar
Electronicals master ;P
Default Window Problem, Need Assistance
I have already tryed searching, but no luck finding what exactly to do.
I took pictures but i cant get my comp to recognize the file. I really need help with this becuase i really dont wanna leave me car around USF with my window down...
the clip that runs into the actual window amp has the following wires
-larger Green with a silver stripe
-Larger Blue with a silver stripe
-Small Blue with a white line
-Small Blue with a black line
-Small white with a red line
-One large black wire(should be ground)
-2 larger white wires with a pink stripe
then there is a two wire clip that i think is actually running to the motor which includes the
-Blue with silver stripe wire
-green with silver stripe wire
I am trying to just connect the motor straight to the battery to get the window up until i can fix the problem...
all help or links would be very appreciated, and repped
Sponsored By Carrabba's
R.I.P. Tim Aldrich
Old Jan 27, 2009 | 07:58 PM
Hellaslow's Avatar
...TR's resident Racist..
blue and green wire might be up and down
just get a hot jumper wire and test the blue and green wire? one up one down...
A clever person solves problems but a Wise person avoids them... A.Einstein
Old Jan 27, 2009 | 08:00 PM
+Waldo+'s Avatar
so if i was already using those and nothing happened then that means my window motor is shot?
The passenger window goes down and up when i touch the two white wires along with the ground...
and if my motor is blown how can i get my window to stay up until i get it fixed?
thanks
R.I.P. Tim Aldrich
Old Jan 27, 2009 | 08:06 PM
Hellaslow's Avatar
disconect the motor from the regulator and manual that bitch up... then somehow rig it to stay up...
cagedeyecam's Avatar
AERODYNAMIC WHEN I FIGHT
wood block. geto way that I have done mine on one of my s14s
Old Jan 28, 2009 | 07:10 AM
+Waldo+'s Avatar
thanks for the help guys, MOD's can delete unless they wanna keep the small amount of info open for search reasons
repped
R.I.P. Tim Aldrich
