putting a 96 motor in a s13
ok so im getting a 96 motor obd2 im getting harness ecu trans, motor. and its going into a 91 s13. seaching takes me to long my computer is slow
so i was just wondering what i have to do to get it running right. speed-o working and rpm gauge. and does the wire harness plug into the body harnesss? let me know please. thanks aron
Toss the S14 harness and ECU in the trash. Just install the 96 motor and put the old S13 electronics back on it. You'll have to use the S13 dizzy to do this (swaps right out). Don't forget to reuse the S13 coolant temp sensors. This is the easiest way to do it and requires NO wiring. I did it this way and didn't even remove the harness!
And save the old S13 cams. You might want them one day.
