putting a 96 motor in a s13
Old Oct 1, 2008 | 05:58 PM
Epstein's Avatar
Retired
The 2 coolant temp sensors, one 1-wire, one 2-wire, should both be swapped out. Ignore the extra crap on the S14 motors. If there's a plug on the S13 harness, hook it up. It's that simple. You can leave off 1 or 2 of the emissions dealies on the intake manifold. TPS, dizzy, mafs, ignitor, O2, coolant, injectors. That's all the S13 ECU needs for I/O to the engine. The 2nd coolant sensor will drive the gauge in the cluster.
So I just literally told you everything you need to know about this engine swap from the electrical side. What's next; do you need a vacuum hose tutorial?
Old Oct 1, 2008 | 06:29 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
So I just literally told you everything you need to know about this engine swap from the electrical side. What's next; do you need a vacuum hose tutorial?[/quote]
hope not. if it doesnt start ill try and talk to you... thanks
Drifting:
most fun you can have
with your pants on.
Old Oct 1, 2008 | 11:23 PM
asia989's Avatar
Why So Serious?
Pm if u need help aron
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
Old Oct 2, 2008 | 09:26 PM
A-ron's Avatar
shall do thanks
Drifting:
with your pants on.
Old Oct 2, 2008 | 09:49 PM
Joevanni's Avatar
do u have to use an s13 ecu on a 91 engine or can i use a 98 ecu on the 91 engine
Old Oct 3, 2008 | 10:03 AM
A-ron's Avatar
i tried using a 91 ecu on a 97 did not plug in
Drifting:
with your pants on.
Old Oct 3, 2008 | 11:22 AM
  #17 (permalink)
Epstein's Avatar
Retired
Your ECU should match your harness. S13 ECU on S13 harness. S14 ECU on S14 harness. SOHC ECU, go away.
Old Oct 3, 2008 | 11:26 AM
  #18 (permalink)
Joevanni's Avatar
ok i know that but will an s14 ecu and wireharness work on a 91 ka24de?
Old Oct 3, 2008 | 12:26 PM
  #19 (permalink)
Epstein's Avatar
Retired
Yes, if you use the S14 distributer. The real problem is when you mismatch harnesses and chassis. That's when you run into a wiring nightmare.
If you're doing ANY wiring on a KA motor swap, UR DOIN IT WRONG!
Old Oct 3, 2008 | 12:41 PM
  #20 (permalink)
Joevanni's Avatar
o ok
