90 240sx Ka24e starting problem
Old Sep 15, 2008 | 02:58 AM
AustinZ32's Avatar
...lost in thought.
Default 90 240sx Ka24e starting problem
Hey All,
My 240sx will start fine when its been sitting for a little while, but if you start it, then shut it off, it has a hard time starting, you have to tap the gas pedal excessivly for it to catch up with itself....any ideas? When it startd up, it runs fine.
Old Sep 15, 2008 | 05:05 AM
Matt Vassallo's Avatar
lifelong learner
this screams of leaking fuel injectors, a very common problem with single cams.
rest in peace tim.
Old Sep 15, 2008 | 05:12 AM
presidential's Avatar
OG Join Date: 6-15-00
+1 on the injectors. Check the fuel pressure, lines and voltage at the pump while you're at it.
1973 VW Squareback
1979 AMC Jeep Cherokee Chief
RIP Tim
Old Sep 15, 2008 | 07:15 AM
AustinZ32's Avatar
...lost in thought.
How do i fix the leaking of the fuel injectors?
Old Sep 15, 2008 | 07:16 AM
Check the o-rings, the injector hat. You can also take them out and take them to a shop that will duty-cycle test them for you. Odds are, they're shot (stuck open) and will need replacement.
1973 VW Squareback
RIP Tim
Old Sep 15, 2008 | 07:22 AM
AustinZ32's Avatar
...lost in thought.
how much do they go for? good ones at that?
Old Sep 15, 2008 | 08:13 AM
Could get expensive if you go new. I'd probably look into a motor-swap to be honest.
1973 VW Squareback
RIP Tim
Old Sep 15, 2008 | 08:32 AM
AustinZ32's Avatar
...lost in thought.
what swap is good, but a fair price?
Old Sep 15, 2008 | 08:48 AM
KA24de (DOHC) is a nice upgrade from the SOHC motor.
1973 VW Squareback
RIP Tim
Old Sep 15, 2008 | 11:08 AM
AustinZ32's Avatar
...lost in thought.
ill work with the SOHC for now, til i get enough money saved up for the swap.
