new problem
Old Aug 29, 2008 | 07:15 PM
Silvia-san's Avatar
fuck
Default new problem
so i almost didnt make it home tonight... when you give the car gas guess wut happens.... nothing. i drove all the way home with my hazards on at 10MPH. and still the same problem, one u drive it it wont start 4 a while. someone said a whole new computer is needed... true?
USMC 3/2 KILO
PS3 GAMETAG: Silvia-san
http://forums.nicoclub.com/zerothread/253879
Old Aug 29, 2008 | 07:25 PM
240Cyanide's Avatar
Function is my form.
have you checked your spark plugs or fuel injectors? same thing happened to me a few times.. also could be your computer, what year is your car?
Old Aug 29, 2008 | 07:28 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
does it rev up at all in neutral??? maybe the trottle cable is broke
can u rev it up by hand under the hood??
and if it is the E.C.U. u can get them off here for less than 45$$
Drifting:
most fun you can have
with your pants on.
Old Aug 29, 2008 | 09:50 PM
Silvia-san's Avatar
fuck
i already replaced plugs and wires. but not injectors... and ya it will iddle really wierd 4 a minute then corects itself and after its corect u can give it gas and drive normal. but if u give it gas while its idling wierd it just makes it worse.
USMC 3/2 KILO
Old Aug 29, 2008 | 09:56 PM
Silvia-san's Avatar
fuck
oh and its a 92 KA
USMC 3/2 KILO
Old Aug 29, 2008 | 10:42 PM
blue_eclipse93's Avatar
dum de dum
you know what I say.....by the time you get done fixing everything wrong with this car...you might as well bought another motor. 4cerealously
Facebook
1993 Mitsubishi Eclipse GS - Lost - L
1990 Nissan 240sx - Totaled(r.i.p)
1991 Nissan 240sx - Sold
1990 Nissan 240sx - Sold
1993 BMW 325i - Traded
1990 Nissan 240sx TotaledTOT
2009 Nissan Sentra -
Sold2005 Yamaha R6 - Sold
2006 Yamaha R1 - Stolen
2000 Nissan Sentra - Daily Driver
Old Aug 29, 2008 | 11:39 PM
im_DTF's Avatar
the 1 N only
check your timing
try resetting your ecu and see if that helps
Old Aug 30, 2008 | 03:12 AM
Epstein's Avatar
Retired
That's a bad maf sensor connector. The connection is loose and sending your car into limp mode.
Old Aug 30, 2008 | 05:40 AM
shinmei2006's Avatar
^ from what i understand the ECU in his car was kinda manhandled when he bought it. Could be the maf like you said though since he just put a cone filter on the stock intake, he may have jostled it.
http://www.hashiriya.net
Old Aug 30, 2008 | 09:00 AM
vertigo's Avatar
U and your 3rd dimension
99.9999% of the time, the ecu is fine (man handled or not) when the car will even fire. They just make good scape goats for people that dont know wtf they are doing.
Meanwhile the MAF is the most important sensor, and can cause exactly what you are describing. Clean the maf connection, and check for post maf air leaks.
And quit smoking so much weed so maybe you can think straight and actually fix your car.
Rear brake only for use when front brakes squeak whilst slowing for hot bitches
