ok S13 problem, angelas old car
here's how we fix this:
angela. who did you take it to that fixed this similar issue the first time? if ted knows, he can probably ask that guy or take it back to him and get it fixed again...it might at least narrow things down.
ted. the car is 15+ years old. you're going to run into some issues. if none of the physical pieces seem to be the culprit, i would start looking at the wiring harness. look for any exposed wire, bends, cracks, breaks. even if it is an ECU code pointing to a particular sensor, it could be the wiring causing the sensor to appear faulty.
good luck.
the rest of you. fucking grow up. seriously.
good luck.
I took it to Na306StAnG (shaun) And he seemed to have fixed the problem. He basically tinkered with everything and got it to start (it wasnt running he had it towed to his shop)
I talked to Ted on the phone lastnight and we came up with a possible solution...
Ted, call me or Sean when you decide.
No the white car was sold to my old room mate and it already has an sr and its RHD
were talking about the maroon one
Angela and i have already talked about it and i was never mad at her to begin with, its on old car and its gonna have problems. i never acused her of anything nore though less of her when this problem started.
i already replaced plugs and wires, changed oil, cleaned MAF, and bought a coolant temp sensor and it still does this. and today it overheated after i already filled it with coolant. im thinking thermostat??? it only refuses to start when its warmed up or on a really hot day. car i just take the thermostat out and run it withouht one????
EDIT: and no it does not smoke at all. smells like it it running a little rich though
USMC 3/2 KILO
PS3 GAMETAG: Silvia-san
http://forums.nicoclub.com/zerothread/253879
USMC 3/2 KILO
i say coolant temp sensor. i had this problem with my ka about 3 months ago. GOOD LUCK!
