5 lug swap question
well you gotta mae sure you get the canooter valve off the 14 or you are screwed.
RIP my very best friend. DJ aka djzstang1 you will be missed dearly. I love you bro.
1995 240sx se
1992 240sx
1990 240sx se
1991 240sx hicas sr20det MDX
1991 240sx project coupe
1990 240sx drift beater hatch
1993 240sx sr20det
1995 240sx se
1992 240sx
1990 240sx se
1993 240sx sr20det
^lol
the backs should be a direct swap. the fronts, iirc the only difference is the size of the holes for the struts. someone correct me if im wrong though because i think i am about the fronts.
Nissan North America - Canton
rears you just swap the hub/rotor
fronts either s14 ball joints pressed into your lca or use s14 lca's.
hub/spindle/rotor
either use sleeves for the spindle or drill out you coilovers or whatever you got bc the bolts on the s14 are bigger.s14 uses 14mm and s13 uses 12mm
dont forget the extra lugs
hub/spindle/rotor
and the axle nut is a 36mm
here is a write up for the fronts
Rexbo’s Guide to the s13 to s14 Front 5-Lug Conversion - 240SX Forums
the site he has on there no longer sells the 5 lug sleeves and the only other place i know of that does is agency power, they sell them for like 40 or 50 bucks
Nike air force 1 ones, Air Jordan shoes, Nike dunks, Air Max Shox, Bape Hoodies - We supply brand shoes (air max, jordan,nike shox,adidas, af1, bape, dunk, gucci, prada, puma, timberland, etc), bags, jeans, hoodies, shirts.website: Nike air force 1 ones, Air Jordan shoes, Nike dunks, Air Max Shox, Bape Hoodies
IM IN VA BITCH!!!!!!
www.rccustomz.com
www.rccustomz.com
