s13 sr problems please help
Old Jun 20, 2008 | 07:02 PM
im_DTF's Avatar
the 1 N only
Default s13 sr problems please help
ok, i just swapped my s13 with a s13 black top sr, mostly stock, just has a mani, dp, front mount and greddy bov. got everthing hooked up and started it first try. it idles fine but under any load it bucks and there is no power like it has a boost leak. i have been over and over the ic piping and there are no leaks. as soon as i try to give it gas it just doesnt want to do anything except buck, sputter, and go no where. i can barely drive it around the block. i unplugged the maf and the motor almost dies so the maf is working.. i am stumped and i need the car for work on monday. anyone have any ideas?
Old Jun 20, 2008 | 07:30 PM
RyanS13's Avatar
doin big thangs
is your bov recirculated? are you running an afc tune or anything?
Pride Performance
Originally Posted by paul kersey
worrying about horsepower levels is totally gay
like, aids of the butthole gay.
Old Jun 21, 2008 | 07:36 AM
im_DTF's Avatar
the 1 N only
bov is open,no safc. that is not the problem though, because the motor came out of my buddies car exactly how i have it and it run fine..
Old Jun 21, 2008 | 11:04 AM
RyanS13's Avatar
doin big thangs
hmm...make sure all sensors are plugged in, make sure relays and fuses are good, make sure your getting spark on all cyl., but i guess its somewhere to start, g/l
Pride Performance
Old Jun 21, 2008 | 11:09 AM
Sohc4now's Avatar
^^^I'm with stupid
check your tps
Old Jun 21, 2008 | 11:11 AM
RyanS13's Avatar
doin big thangs
^ya that too
Pride Performance
Old Jun 21, 2008 | 12:23 PM
im_DTF's Avatar
the 1 N only
i will check that when it stops raining. how do i check the tps
Old Jun 21, 2008 | 03:47 PM
Sohc4now's Avatar
^^^I'm with stupid
Nissansilvia.com -> TPS Throttle Position Sensor (SR20) - Hardtuned.net
Old Jun 21, 2008 | 06:09 PM
im_DTF's Avatar
the 1 N only
ok, i cant find my volt tester so i cant check the tps tonight but i will buy one tomorrow and check it. i did however mess with the timing and it is running soo much better, the car trys to boost but it just cuts out and falls on its face. i just reset the ecu and i am going to go out and try it and see what happends.. any other ideas would be great.
