VG30DE questions
Old Jun 5, 2008 | 04:10 PM
psychx's Avatar
Default VG30DE questions
The VG30DE engine, is anyone familiar with this? I am just wondering if there are any known problems with it or if it is a fairly reliable engine? Any tips on some power adders? ie: cams or fi, i believe the compression is 8.5:1 but im not completely sure.. Just wondering some information and input on this nissan/infiniti engine. Thank yuo in advance,
mike
Old Jun 5, 2008 | 06:47 PM
psychx's Avatar
Another quick question, if I can't find a part for the Infiniti J30, I should still be able to get something for a Nissan 300ZX since they use the same motor... correct? IE: cold air intake or headers?
Old Jun 5, 2008 | 06:58 PM
Slo_Silver's Avatar
Bottle Fed
wut year is the car that the motor is in ?
Old Jun 5, 2008 | 07:01 PM
IThaJokaI's Avatar
Hates cars...
Swap out the VG30DE for a VG30DETT... Theres your power adder. Now for the intake I doubt it will word because of the different engine bays... And the headers should work depending on clearance issue.
Old Jun 5, 2008 | 07:14 PM
psychx's Avatar
ok I read about it... is it the same motor, just with twin turbo? Or is it a completely different setup?
Old Jun 5, 2008 | 07:29 PM
sameo2's Avatar
infiniti tech
^ diferent plenum,pistons,injector and cas conector.
Old Jun 8, 2008 | 12:40 PM
Tampapulsar's Avatar
Not a Noob
Do you have a Maxima or Infiniti? You can put an intake, y-pipe, UDP. Exhaust studs are known to break. Auto transmissions are weak as well
