car dosent accelerate well.
Old May 19, 2008 | 09:25 PM
170k240's Avatar
Will Drift For Tires
if your engine is stock, a stock clutch will do.
Nissan North America - Canton
Old May 20, 2008 | 02:21 PM
Speed cat's Avatar
speed cat
ok, as of today the car really dosent accelrate at all. Just liek my GST did when the clutch was roasted. SO Im assuming its the same thing, I mean like my car litterly goes fuckin nowhere. Just happend after I pulled outta work.....nice.
Old May 20, 2008 | 02:58 PM
norachelhere's Avatar
fails.....
Originally Posted by Speed cat
so when I drop the clutch ease out a little esier? also is it just that a new clutch dose that when you dump it or a clutch that isnt higher end that dosent have the capacity to grab fast....as in do i need a clutch made of better material and higher hp rating? i know putting a clutch in for too high a hp rating will hinder performance.
yes, ease off a little easier. Your old worn out clutch slipped more, so you could dump off of it quicker and basically let the clutch ease itself into gear. Make sense?
Either rev up higher like you should to dump the clutch, or ease off more...
as for the higher end or material thing, forget all of that. It doesn't make sense, just erase it from memory and try again
as for the clutch rated for more power, it won't hinder performance, it will hinder driveability. But, in my opinion, that has more to do with the driver skill than the equipment. There are numerous people that would, and do, drive around on 6 puck un sprung clutches. You know, the ones that everyone says you can't daily driver on...
Unless there is actually something wrong with your motor, I'm thinking it is driver error that it making it seem like there is a problem...
Old May 20, 2008 | 02:59 PM
fails.....
didn't you just replace that clutch? or am I thinking about something else?
it isn't that hard to pull apart... might as well pull it apart and take a look ...
Old May 20, 2008 | 05:32 PM
95hondaC's Avatar
My car has been doing the exact same thing... weird.
