Slave cylinder question
Old May 12, 2008 | 01:03 PM
JaxS13Racer's Avatar
Sold my sol for Silvia
Default Slave cylinder question
I've got a slave cylinder laying around for a KA and I'm wondering if it will work on my SR tranny. I have to pump the clutch in the mornings because there is about an inch and a half of play in the pedal but after that it's fine for the rest of the day. Thanks
Old May 12, 2008 | 01:47 PM
shinmei2006's Avatar
yes
http://www.hashiriya.net
Old May 12, 2008 | 02:07 PM
norachelhere's Avatar
fails.....
yeah, as far as I know, they are the same...
It should just bolt right up for ya.
make sure you bleed the hell out of the system afterwards...
Old May 13, 2008 | 01:41 PM
I've gotten quite good at bleeding the brakes and clutch on this car, it seems like every time I work on the car I have to bleed one or the other for some reason.
Old May 14, 2008 | 08:25 AM
fails.....
yeah, I know the feeling. I went through that phase with my coupe a while back....
Old May 14, 2008 | 12:56 PM
Speed cat's Avatar
speed cat
yes, the rear of the tranny is interchangable and exactly the same as the one on the kas except the dust cover at the end is bigger on the sr. same parts. commen swap i a sr end with ka bellhousing.
