could use some help???
ok first question ive got an s14 sr and its running like shit until it gets to 2k and at idle it sounds like it has cams its real lopety but its all stock i think it might have something to do with the vvti. any ideas?
idle like shit? does it sound like a suby? does it studder? slow to accelerate?
this is what it does exactly
thats it for now id appreciate any help
thanks
Allen P.
thanks
Allen P.
2nd wil j30 axles bolt up to a stock diff?
thanks
Allen P.
thanks
Allen P.
on j30 axles, if there 6bolt, then yes they will, if there 5 bolt, they wont unless you use the j30 diff as well.
yes all of this more like a srt4 tho
no breaking up at high rpm's just runs shitty at low sounds like its not running on all 4 cylinders
whats wrong with it?
sounds like it's not running on all 4 cylinders
does the car buck while accelerating or is it just a slow constant acceleration?
i figured that but y any ideas
check to see if it's actual misfire first.
start the car and unplug each coilpack one at a time to see if the idle gets worse. if the idle stays the same, that's the culprit.
