Energy Suspension Polyurethane Bushing Kit?
I can get to a press at my friends shop and I have a sawzall/propane cylinder torches to get them out, I'll let you guys know how everything goes!
only the t/c and front lower arm bushings are in 3 pieces since those are usually the ones people do more commonly.
im about to get the full kit, plus some steering rack bushings..if you're not going to do heim jointed baller adjustable arms these are the way to go. i'm fed up with the slop and stuff.
while you're at it, i would definitely recommend getting some steering rack bushings, they're like $20 or less and take 10 minutes to install.
and i'd look into some ball joint replacements while it's all apart. moog makes oem replacements for the front (pdmracing.com or enjuku/insert local shop could get them).
for the rear ball joints, nissan only sells the rear lower arm/ball joint as a single unit, so it's not worth it, but you can buy 91-94 b13 sentra ball joints. they are 1mm bigger, but they press in with no problems and work fantastic.
since you'll be getting all the press work done, i'd surely do those. i've felt the difference on older chassis' and it's pretty nice for the money.
i replaced all of the bushings except for the rear lower control arms and subframe inserts. going to s14 rear lower control arms and getting better subframe bushings. the car feels so much better now that the bushings arent crap.
Blake, if you have all of them, and you have the Explorer to drive, just replace all of them.
Unless you plan on getting adjustable everything, it's worth the extra time. Or you can just give me the kit for $5 and save yourself the trouble of installing any of them.
-'03 GSX-R 750
-'03 GSX-R 750
do plan on getting adjustable front suspension but I wasnt sure on the rear other then ruca's.
I have the new Explorer to drive and the coupe will be sitting for awhile, guess I will just wait and see what bushings to install.not a big deal.
