new clutch but 2nd gear is acting up?? why???
just curious why my tranny is acting a bit funny now i put a newclutch in over the weekend now 2nd gear catches like every timeand same with third but not as bad as 2nd.... i did loose some gear oil but i put some back in just thought the shifter hole... i didint use the fill plugg...would this be becuase i have a lack of gear oil/??? or does it have to do with something else??? Noob Question
I'm betting on low on gear oil. And/or air in the lines. Unlikely cuz you don't have to open the system to change out the clutch. but if the slave isn't moving enough, it would make it seem like it was shifting funny.
It is either that, or you make a mistake putting the clutch in...
recheck the slave, it might have been on its way out, and fucking with it sent it over to piece of shit land.
most likely not clutch related since it only happens in certain gears.
recheck and make sure its definitely gear, and not rpm.
